Joined: 06/02/2013(UTC) Posts: 5 Location: at home Was thanked: 1 time(s) in 1 post(s)
Hi I would like to make a request to improve the plot functionality. some features I would like to see would be 1/ auto-scale the axis to fit the dataset being plotted by default. (don't assume 0 is a sensible start or mid point of an axis) 2/ provide a way to manually set the scale of the axis, and control number of divisions or the increment between each division. 3/ the ability to specify either axis or both as a log scale 4/ provide a way to specify that the axis values are in SI multiples i.e. f,p,n,u,m,k,M,G,T etc.without having to multiply / divide the dataset. Thanks for a good product Steve
1 user thanked stevec for this useful post.
Originally Posted by: stevec 4/ provide a way to specify that the axis values are in SI multiples i.e. f,p,n,u,m,k,M,G,T etc.without having to multiply / divide the dataset.
A natural way to do so would be to specify the axis limits and/or divisions using quantities with appropriate units (including multiples of existing variables). Martin |
Why not ? In the future the 2d graph control on SMath could have the same usability as these opensource javascript webapps : graphr.org graph.tk Edited by user 07 February 2013 04:41:50(UTC)
