Offline Illbay
#1 Posted : 01 May 2013 22:59:14(UTC)
Illbay
United States
Greetings.
Have enjoyed using this as a successor to the commercial product which it seems to work like. I created a sheet in the XMCD format earlier, and now it is unable to open in the new version. Following is the information in the error dialogue that comes
<FileName>.XMCD
Could not load file or assembly 'TextRegion, Version=1.9.4868.42191,
Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system
cannot find the file specified.
The program does load, and is able to create a NEW sheet; as far as I can tell it works all right, just simply cannot load the existing .XMCD format file.
Illbay attached the following image(s):
Offline Andrey Ivashov
#2 Posted : 02 May 2013 00:34:38(UTC)
Rank: Administration
Fixed. Will be available in the next version.
Offline RASG
#3 Posted : 02 May 2013 23:40:02(UTC)
RASG
Argentina
Andrey, this is an amazing job you have done with this program! I have a problem when I start SMath: apparently it can not load a group of plugin because it can't find the file 'mcaduser, version= 1.04614.654'. I don't konw it this problem is mine or a bug. Thank you.
RASG attached the following image(s):
Offline uni
#4 Posted : 03 May 2013 01:27:30(UTC)
uni
This is my problem. Mathcad EFI plugin doesn't work in the new version. So, it must be removed. Remove two files: mcaduser.dll and mcadefi.dll.
Russia ☭ forever
Viacheslav N. Mezentsev
#5 Posted : 03 May 2013 11:19:07(UTC)
As I investigated situation with mcaduser caused by the same issue as described about XMCD. Issue already fix.
Uni, please, contact me via Skype - I'll give you latest internal build of SMath Studio to check how your plug-ins work.
Regards.
Offline RASG
#6 Posted : 03 May 2013 19:48:20(UTC)
RASG
Argentina
Abdrey: thank you for you interest in the problem. I really appreciate this amazing tool for my academic job (iI am teachenig numerical methods in college) an as civil engineer.
#7 Posted : 07 May 2013 02:10:09(UTC)
Fix available in SMath Studio 0.96.4875.
Best regards, Andrey Ivashov.
Guest (2)
