Joined: 17/06/2012(UTC) Posts: 26 Was thanked: 1 time(s) in 1 post(s)
Hi all,Trying to reopen a file that I wrote and that refused to be closed normaly, I receive this message: "Unexpected end of file occured. The following elements are not closed: result, math, region, regions. Line 82490, position 12."
I posted the file here: fileIs it possible to recover the file ? If yes, how ? Thanks a lot for any help,
IoanEdited by moderator 04 July 2012 01:00:11(UTC)
the link to the file points to a hoster which requires login/registration. I won't create a login at a filehoster just to download a single file. You might use dropbox or the smath wiki file management.
The problem might be solved by just closing the xml tags in the file, but I can't try...
If that is the solution than I guess that SMath should be able to propose this approach and apply the fix.
Best regards, Martin
Hi, Originally Posted by: kmihaylovich I agree, Ioan please attach the file directly to the forum or use a registration-free hosting service... Originally Posted by: mkraska The problem might be solved by just closing the xml tags in the file The solution is indicated by mkraska and the result is in the attached file regards, w3b5urf3r Edited by user 03 July 2012 10:19:08(UTC)
| Reason: Not specified File Attachment(s): Davide Carpi attached the following image(s): |
Thanks for your answers, Many thanks to w3b5urf3r for the recovered file. Now the original file is attached to my first post. I still have a problem with this file: all results are in fractional mode, against my temptatives of changing. Edited by user 03 July 2012 10:45:28(UTC)
You are welcome Originally Posted by: Ioan all results are in fractional mode, against my temptatives of changing. simply change the result optimization from "none" to "numeric" regards, w3b5urf3r Davide Carpi attached the following image(s): |
Thanks again w3b5urf3r.
Best regards to all,
Ioan
Hello there, I have similar problem with my document. I saved file on hard disk but when i reopened it all text below pagebreak stamp disappeared. Please look at it, help if possible it is important for me. Best regards.
Joined: 04/07/2010(UTC) Posts: 178 Was thanked: 19 time(s) in 13 post(s)
I don't find anything wrong with your file. It opens fine on my computer with Win 7 and SMath 0.95. You have collapable areas within a collapsable area. |
Ed |
Hi there, I have one more corrupt file. This time I can not even open it. Thanks for every help.
Thanks for every help. Hi Anonymous, The recovered file is in the attachments. @Andrey The issue is in these lines, at the end of the Anonymous original file... Code:
<region id="163" left="0" top="7227" width="326" height="334" color="#000000" bgColor="#ffffff" fontSize="10">
<math error="9">
<input>
<e type="operand">Typ</e>
<e type="operand" style="string">1</e>
<e type="operator" args="2">≡</e>
<e type="operand">A</e>
<e type="operand">b</e>
<e type="operand">2</e>
<e type="operand">d</e>
<e type="operator" args="2">*</e>
<e type="operator" args="2">+</e>
<e type="bracket">(</e>
<e type="operand">1</e>
<e type="operator" args="2">:</e>
<e type="operand">A.2</e>
<e type="operand" style="string">Nie dotyczy</e>
<e type="function" preserve="true" args="4">line</e>
<e type="operand" style="string">2</e>
<e type="operand" style="string">3</e>
<e type="operator" args="2">|</e>
<e type="operand">B</e>
<e type="operator" args="2">-</e>
<e type="operand">H</e>
<e type="operand">h</e>
<e type="operator" args="2"><</e>
<e type="operand">L</e>
<e type="operand">l</e>
<e type="operator" args="2">&</e>
<e type="operand">d.1</e>
<e type="operator" args="2">≥</e>
<e type="operand">d.2</e>
<e type="operand">#</e>
<e type="function" preserve="true" args="5">line</e>
<e type="function" preserve="true" args="2">if</e>
<e type="function" preserve="true" args="4">if</e>
<e type="function" preserve="true" args="3">if</e>
</input>
</math>
</region>
regards, w3b5urf3r Edited by user 18 September 2012 11:26:12(UTC)
Thanks for help w3b5urf3r. It is working now.
Hi, Unfortunately I have a similar problem with my file. After I finished my document it didn't saved somehow and now when I'm trying to open it I just see a grey background I would be really grateful if someone could help me with it, because it's very important for me. Best regards, Ann File Attachment(s): Słupy.sm (2,676kb) downloaded 15 time(s).
Hi Ann163, here there is whatever is recoverable. I wish you an happy new year, Davide File Attachment(s): Słupy.sm (2,677kb) downloaded 21 time(s). |
Hi w3b5urf3r, thank you very much for fixing it I also wish you a Happy New Year! Ann
