8 Pages«<678
#141 Posted : 05 April 2016 22:12:31(UTC)
Was thanked: 872 time(s) in 583 post(s)
Ciao Sergio, Good
Originally Posted by: PompelmoTell Go to Quoted Post
Hello Davide,
I have problems with the export XeLaTeX.
First it is highlighted exception
Proceeding is inhibited the choice of options
Proceeding is nevertheless produced a tex file
You must still add the following line in the markup to fill in XeLaTeX
\newcommand{\defeq}{\coloneq} % SMath 'define equal' symbol
I see, seems something related to multithreading vs Forms. I have to ask Andrey, but I think that I have to remove the dialog from the save flow.
PS some addition function is not implemented, however, the qualitative result of the prints obtained is much higher than that of normal export pdf. I would hate a little if this project was abandoned
The project is not abandoned, but you know, there are a lot of plugins and I have to find a little bit of time for each one. I'll implement the missing functions ASAP. Good
Edited by user 05 April 2016 22:14:30(UTC)  | Reason: Not specified
Best regards,
Davide
If you like my plugins please consider making a donation to SMath Studio
on 06/04/2016(UTC)
Offline PompelmoTell
#142 Posted : 06 April 2016 10:18:02(UTC)
PompelmoTell
Was thanked: 31 time(s) in 25 post(s)
Ciao Davide,
with regard to functions not implemented do not worry there is always the possibility to act manually (thank you for the tremendous efforts of multiple plugins). For the mistake the question is more annoying: Andrey hopefully give a solution.
#143 Posted : 08 April 2016 18:03:26(UTC)
PLUGIN UPDATED SMath Studio 0.97.5346 and later
- SS 0.98: fixed crash on save due to the Forms vs MTA;
- ODT, TEX files: added Command Prompt flags (see documentation in 1st post);
- ODT, TEX files: added more functions (vectorize, Floor, Ceil, at, cases, ternary booleans, absolute-definition's functions), fixed glitches in functions' names in ODT files, minor fixes & improvements;
- TEX files: all worksheet's metadata are now stored in the \doc***** variables;
Edited by user 08 April 2016 19:03:06(UTC)  | Reason: typo
Best regards,
Davide
on 08/04/2016(UTC)
#144 Posted : 08 April 2016 20:15:18(UTC)
PompelmoTell
Hello
the problem indicated in the post #141 has been resolved
thanks 1 user thanked PompelmoTell for this useful post.
on 08/04/2016(UTC)
Offline mayIcomeiN?
#145 Posted : 07 June 2016 10:27:18(UTC)
mayIcomeiN?
How can i download plugin or dll file and then install it to my PC and save .sm file in ODF, not in ODT (ODF Text document)?
I need this to be a formulas that can easy edit in MS Word lately.
Please, give straight link on plugin or help me to solve this promblem.
kursach SG.sm (377kb) downloaded 9 time(s).
Edited by user 07 June 2016 10:35:01(UTC)  | Reason: add file
Offline mikekaganski
#146 Posted : 07 June 2016 10:48:30(UTC)
mikekaganski
@mayIcomeiN, здравствуйте Good
To download and install it, you need to go to menu Tools->Plugins, there make sure that "Plugins" is selected in the left pane, then click the "Local Storage" button over the plugins list, select "Online Gallery" and find the plugin there. Select it, and click "Install" at the bottom of the window.
If you want "ODF", but not "ODT", then there is no such thing as pure "ODF". There are a number of Open Document Formats available, among them: ODT for text documents, ODS for spreadsheets, ODP for presentations, ODG for drawings, etc. What do you need specifically? MS Word since 2007SP2 is able to open ODT, Excel understands ODS, ... so what do you need? I cannot tell if they will import formulas OK, but that's up to you to test.
Best regards,
Mike Kaganski
Offline mayIcomeiN?
#147 Posted : 07 June 2016 11:13:10(UTC)
mayIcomeiN?
Hello.
If you may, please answer me in russian.
There is no plugin "DataExchange" or similar with "odf,odt" in discription.
I already have plugin who called "DataExchange", but he dont' do his own case in particular that announced there
Originally Posted by: Davide Carpi Go to Quoted Post
ODF Formulas (to export variables and functions);
I want the formula looks like this Clipboard01 - kopija.jpg.
But after i saved my file in .odt ( ODF text doc.) wordpad told me that there is content who was incorrectly
displayed.When i tried to open file in Word (2007 version) it cant be open beacuse Clipboard01.jpg
Translation: "Cant open file Office Open XML because of errors in his content"
#148 Posted : 07 June 2016 11:29:45(UTC)
mikekaganski
Originally Posted by: mayIcomeiN? Go to Quoted Post
Hello.
Хорошо Good
Это потому, что ...
Если какой-то плагин уже установлен, он не отображается в диалоге, пока к нему не выйдет обновление (тогда он будет подсвечен).
I want the formula looks like this ...
displayed.When i tried to open file in Word (2007 version) it cant be open beacuse ...
Это не плагин "не делает того, что заявлено", а хреново работает MS Office. То, что WordPad не может его прочитать - так он вообще мало что может. А вот 2007 версия офиса, в которой появилась впервые поддержка ODF, получила очень плохую репутацию за некорректную поддержку - Майкрософт тогда вообще обвинили, что они саботируют ODF такой поддержкой.
Вот файл, открытый MS Word 2013 и пересохранённый в docx: kursach SG.docx (113kb) downloaded 5 time(s).
Best regards,
Mike Kaganski
thanks 1 user thanked mikekaganski for this useful post.
on 07/06/2016(UTC)
Offline mayIcomeiN?
#149 Posted : 07 June 2016 11:44:35(UTC)
mayIcomeiN?
Благодарю за поддержку!
Thank for help!
Edited by user 07 June 2016 12:44:40(UTC)  | Reason: Not specified
#150 Posted : 12 August 2017 14:10:18(UTC)
Was thanked: 609 time(s) in 405 post(s)
The importData.ODS function does not work in SMath 0.98.6398 (error message: function not defined)
Is the plugin not supposed to work in the latest beta?
Portable SMath with plugins and interactive handbook: http://smath.info/wiki/SMath%20with%20Plugins.ashx
on 14/08/2017(UTC)
#151 Posted : 16 August 2017 20:53:12(UTC)
Fixed, thank you!
PLUGIN UPDATED
Best regards,
Davide
on 16/08/2017(UTC)
Similar Topics
[Data Exchange Plugin] Export data (more than 4 columns) (Questions)
by chandragon 29/03/2017 12:08:24(UTC)
8 Pages«<678
