An amazing math tool, a must-have for engineers and scientists everywhere. (And it's not bad as a quick expression evaluator, either.)
more...
by Mike Williams
Fantastic free software. Have used it for several structural calculation reports
more...
by Martin Kynde
A very useful tool for engineers. Thanks a lot. Keep up the great work.
more...
by Bhargav
on 07/11/2019(UTC), on 07/11/2019(UTC), on 07/11/2019(UTC), on 07/11/2019(UTC), on 08/11/2019(UTC)
This time I've spent many time on improvements of symbolic engine to make it more safe and predictable. To show some results I've made available equrep(3) function which is hidden from auto-completion list and other places. It demonstrates possibilities to manipulate with complex structure of different equations. I'm not sure if anyone interested in this function at all, but under the hood it is used almost for every calculation in the program. This function has three arguments: - First is a given equation (anything to manipulate with); - Second is an input for manipulation rule; - Third is an output of manipulation rule. In other words it allows to apply some manipulation (described in two last arguments) to an equation (from the first argument). Some examples: Do not forget to set Optimization=None if you want to see exact result without any extra numeric or symbolic optimization. Best regards.
on 07/11/2019(UTC), on 08/11/2019(UTC), on 08/11/2019(UTC)
Originally Posted by: Andrey Ivashov This function has three arguments: - First is a given equation (anything to manipulate with); - Second is an input for manipulation rule; - Third is an output of manipulation rule.
looks promising. Maybe, this might simplify restructuring of terms inside plugins. As it seems, the function does not preprocess it's first argument. The definition of c isn't during the call of eqnrep when running the sheet step by step. I see that the structure patterns should be unevaluated otherwise you would rely on having the variables therein being undefined in the sheet. How about a function or a flag enforcing preprocessing? equrep.sm (6kb) downloaded 18 time(s). |
Actually an equrep function with preprocessing can be made: equreppp.sm (18kb) downloaded 16 time(s). |
С некоторых пор возникла проблема непечати некоторых элементов. Расчеты делаю в Вашей программе, затем вывожу на печать в формат PNG и вставляю результат в Word. Возникает проблема с блоками, отмеченных как "Запретить вычисление". Раньше над ними (в правом верхнем углу) был прямоугольник, сейчас они отмечены серым фоном. А с ним как раз и беда. Что можно сделать? На просмотре так:
На печати так:
Как видно не все блоки напечатаны, причем некоторые из нерасчетных были всё же напечатаны. Ранее (когда не было фона) таких проблем не возникало. Для печати использую виртуальный принтер pdf24. Стандартный экспорт в PNG формат не делит на страницы, так бы им пользовался (там кстати проблем нет). Пока вышел из ситуации с помощью скриншотов. Костыль конечно, но ничего не поделать. Edited by user 08 November 2019 21:47:42(UTC)
Hi. An application for equrep: step by step derivatives. D.sm (15kb) downloaded 38 time(s).Best regards. Alvaro.
on 11/11/2019(UTC), on 14/11/2019(UTC)
Another. isol.sm (43kb) downloaded 42 time(s).Best regards. Alvaro. Edited by user 14 November 2019 10:57:08(UTC)
I don't understand the maple fake [isol]. Already such a superb companion to Smath.
And another: laplace transform in native smath. laplace.pdf (155kb) downloaded 33 time(s). laplace.sm (85kb) downloaded 32 time(s).Best regards. Alvaro.
Originally Posted by: Jean Giraud I don't understand the maple fake [isol]. I like native. I wish items like Writer Region would go native too.
Originally Posted by: ElSid I wish items like Writer Region would go native too. That's in the plans, but it requires some new things and some refactoring before this step. |
Originally Posted by: ElSid I like native.I wish items like Writer Region would go native too. That means an extra icon in menu or special key. Finally: did you manage your translucent background ? Did you manage the *.PDF c/w the translucent like original ?
Alvaro or Jean, When Isolating in either the snippet or Maple, is there a way to force the symbolic engine? I tried using after some of the variables were defined (Yes, I used CTRL+=) and they both work prior to variable assignments. The issue is that many times, we define the variables and further down the calculation shows the equation ... that I'd like to manipulate. I tried setting optimization to none and symbolic, both failed
Originally Posted by: Jean Giraud That means an extra icon in menu or special key. OK. Better documentation Originally Posted by: Jean Giraud Finally: did you manage your translucent background ? Yes Originally Posted by: Jean Giraud Did you manage the *.PDF c/w the translucent like original ? PNG and yes. The graphic I was sent had very rich colors, almost like the flowers in the example. It was hard to see the text/calculation
Originally Posted by: Jean Giraud I don't understand the maple fake [isol] It’s better to turn off optimization to see the native maple answer. Edited by user 21 November 2019 20:48:22(UTC)
3 users thanked uni for this useful post.
on 21/11/2019(UTC), on 21/11/2019(UTC), on 21/11/2019(UTC)
Originally Posted by: ElSid Alvaro or Jean, When Isolating in either the snippet or Maple, is there a way to force the symbolic engine? I tried using after some of the variables were defined (Yes, I used CTRL+=) and they both work prior to variable assignments. The issue is that many times, we define the variables and further down the calculation shows the equation ... that I'd like to manipulate. I tried setting optimization to none and symbolic, both failed Hi ElSid. I know that SMath carry the definitions instead the values, and with symbolics there are not an eval equivalent. But without an specific example, this is what I get Best regards. Alvaro.
I forgot the screenshot due to a meeting! The space between the equations has some variables "defined". Maybe what I'm looking for is a feature request. I have the same issue with Maple plugin. Essentially, I'm transferring a hand calculation and wanted to show all the steps in order. It does not make sense to isolate and manipulate an equation that is not used for 3 pages ... it's out of sequence and out of context This screenshot is valid for both optimization=symbolic and none
Originally Posted by: ElSid ... Maybe what I'm looking for is a feature request. I have the same issue with Maple plugin. ...
Hi ElSid. I guess that what you want is the 'x:=x' mathcad feature, which hide the value of x for the symbolic processor, but not for the numeric one. This is a mathcad 11 screenshot Best regards. Alvaro.
± You mentioned 'Native Smath' maple is not a plugin from Insert Menu, rather resident from f(x) menu. No need to scratch the right ear with the left hand. Further: your stuff must be tracable/accepted/visible.
Hello Andrey and everyone, I wonder if, since equrep(3) now gives access to smath's internal representation it should be possible to get this "engineering" way of writing equations, discussed in many posts since many years, like here: https://en.smath.com/for...umbers-in-equations.aspxto summarise: a:=2 b:=pi p:=a*b ------------------- symbolic equation =2*3.14 ----------- equation with variables replaced by their values (with control of their format, accuracy, etc.) =6.28 -------------- numerical result This is a numerical equivalent of the visual control that was available to civil engineers at the time of graphics statics. It gives an immediate feel of the magnitude of values, their accuracy and relevance for the result. We can easily do as below: a:=2 b:=3 p:=a*b ----------------------------- (definition) equrep(p:=a*b,x,x)=2*3 ------------- (no optimisation) equrep(p:=a*b,x,x)=6 --------------- (numeric optimisation) and by not displaying input data: p:=a*b 2*3 6 However the middle equation becomes unreadable as soon as we have values that are not round numbers, so we also need to control the format of the values of variables in the middle equation, and to insert some "=" in-between. This is much beyond my ability! If anyone had some idea how to do something close to that, that would help some structural engineers! Thanks, Laurent Originally Posted by: Andrey Ivashov This time I've spent many time on improvements of symbolic engine to make it more safe and predictable.
