SMath Studio Forum
Bugs & Problems
"Structural Beam Analysis" plugin error
Hi everybody, I'm trying to use the Structural Beam Analysis plugin, but I've got some problems. When I open the “Beam Analysis” example I've got the next problem. The error says "Indice fuera de los limites de la matriz" (Index outside matrix boundaries) Could somebody help me with that? Thanks in advance
Originally Posted by: Eneko I'm trying to use the Structural Beam Analysis plugin, but I've got some problems. Will be easier to doctor from the document, isn't it ?
Originally Posted by: Jean Giraud Originally Posted by: Eneko I'm trying to use the Structural Beam Analysis plugin, but I've got some problems. Will be easier to doctor from the document, isn't it ? I've got the problema with the example that's why I didn't send the file before. You can find it attached. Thanks Beam Analysis Input Guide.sm (87kb) downloaded 70 time(s).
Do an AppVersion on the file There has been a lot of work under the engine by the developers since this was issued. You'll need to update it and preferably, repost. I don't do a lot of beam calcs, so I have not touched this in a while. NOTE: Opened fine in 7251 Edited by user 17 January 2020 18:42:00(UTC)
I have the same problems as Eneko, with 7251 versions of SM sergio
I've tryed in different ways to fix it but I continue with the same error.
works perfectly on SS7251 Best Regards Carlos
Originally Posted by: ElSid Do an AppVersion on the file There has been a lot of work under the engine by the developers since this was issued.You'll need to update it and preferably, repost.I don't do a lot of beam calcs, so I have not touched this in a while. NOTE: Opened fine in 7251 The original file showed Red while opening, but finally opened successfully in SS 7251. Then saved as with a new name, which opens later without any such hassle. |
I continue with the same error. Could somebody show me how to solve it please? Thank you in advance
Originally Posted by: ndtma The original file showed Red while opening, but finally opened successfully in SS 7251. Then saved as with a new name, which opens later without any such hassle. The renamed file is attached, including the PDF. I did not do any changes. Hope you will be able to open it. Also update relevant plug-ins. Cheers!. Beam Analysis Input Guide_TEST.sm (388kb) downloaded 52 time(s). Beam Analysis Input Guide_TEST.pdf (487kb) downloaded 58 time(s). |
I confirm the problem highlighted by Eneko also on my pc with win7 Pro and SM SM "0.99.7251.32800". The only dependency reported in the guide is the plugin "Structural Beam Analysis Utility Functions by Redem Legaspi Jr." that is set up and active.
Originally Posted by: PompelmoTell I confirm the problem highlighted by Eneko also on my pc with win7 Pro and SM SM "0.99.7251.32800". Mine is Win 10 Home Edition. SS version same as yours. Cheers! |
Page Beam Analysis Utility Functions exists but I see this plugin for the first time. If anybody find sources I can update them to work state. Quote:Analysis of Beam with any number of supports and with any type of loadings. The worksheet requires that the associated Plugin (Structural Beam Analysis Utililty Functions by Redem Legaspi Jr.) be downloaded and enabled from SMath Studio Extension Manager tool. The worksheet does the following: 1.) Plots Beam Diagram, Shear Diagram, Moment Diagram, Deflection 2.) Calculates Support Reactions 3.) Calculates Shear, Moment, and Deflection at any given point. Refer to 'Beam Analysis Input Guide.sm' on how to use the plugin. redemlegaspi1968@gmail.com Edited by user 21 January 2020 18:50:57(UTC)
on 21/01/2020(UTC), on 21/01/2020(UTC)
Same problem as Eneko and PompelmoTell :___(
Thanks fro helping ndtma and uni!
Originally Posted by: uni Hi uni and thank you very much for offering your help.. I'm going to try to find the sources you asked for, mailing Redem Legaspi. Any specific file or extension? Hugs! Zigor
Originally Posted by: zigoreto I'm going to try to find the sources you asked for, mailing Redem Legaspi. Any specific file or extension? Redem Legaspi can ask Anrey how to upload sources to svn. After that we'll can maintain his project without author. As far as I can see, the last update was made by Andrey. Maybe he has sources. |
You're right, uni..
I've already contacted Redem and he suggested me also writing Andrey; Redem can't recover right now plugin sources.
I've mailed Andrey. I'll keep you informed.
Thanks a lot for helping!
Zigor
Hi I have the same problem with the Beam Analysis, have you got some answer?
Hello. Sources of Beam Analysis Utility Functions stored on SMath server but author of a plug-in asked not to share them. Several days ago I've got permissions to fix an issue. Originally Posted by: Eneko Could somebody help me with that? Plug-in functionality restored now. Tested ok with all available sample worksheets. New version of a plug-in available using Extensions Manager. Best regards.
on 05/02/2020(UTC), on 05/02/2020(UTC), on 05/02/2020(UTC)
Dear Andrey,
I've just download the plugin and check the SMath sheet.
I've only performed few tests, but it's working perfectly.
Thank you so much for your help and effort. Really.
Best regards!
Zigor
SMath Studio Forum
Bugs & Problems
