Hello, This is an old file of mine which crashes SMath in the recent version as well. The same file was already mentioned some time ago, but it seems it remained problematic (at least for me). Maybe Andrey forgot about it . Could someone else try to just open it please in order to confirm the crash. Regards, Radovan Edited by user 09 May 2013 13:44:37(UTC)
I can confirm the crash. If you disable automatic calculation in the settings, then you can load the file. Seems that the first call to roots() generates the problem. |
I confirm, it also crashes for me Win64
1 user thanked PompelmoTell for this useful post.
Originally Posted by: mkraska I can confirm the crash. If you disable automatic calculation in the settings, then you can load the file. Seems that the first call to roots() generates the problem. I nagged many times about roots(), and I hope that only roots() is the source of the problem. Anyway, this cause of crash should be removed, if possible. Fortunately, there is Davide Carpi (w3b5urf3r_reloaded) and his NonlinearSolvers plugin Regards, Radovan |
No crashes for me in smath-mono. Vista home basic 32-bit sp2
Originally Posted by: kilele No crashes for me in smath-mono. Vista home basic 32-bit sp2 Yes, I experienced the same thing before. Will test it again when I get to my Linux distro. Regards, Radovan |
on 09/05/2013(UTC), on 09/05/2013(UTC), on 09/05/2013(UTC)
