They talk about us
This mathematical tool is very useful. I was a Mathcad user, now I use SMath in all courses I teach and ask my students to use it.
more...
by Waluyo Adi Siswanto
I've used this software for several years and can not use anything else for work. I'm a mechanical Engineer and use this for any calculations I do.
1) To show and check my work
2) to set values and write descriptions so I can reuse my formulas for other projects.
This is better than any calculator.
Thank you Smath for such a great software.
more...
by Shawn Paul
Thank you very much for your work and for you programm. I have just started to use it, but already see that it's a wonderful tool for engineers.
more...
by Ilya Shulika
Edited by user 20 June 2022 14:44:23(UTC)
on 25/08/2020(UTC), on 25/08/2020(UTC), on 25/08/2020(UTC), on 25/08/2020(UTC), on 25/08/2020(UTC), on 25/08/2020(UTC), on 26/08/2020(UTC), on 26/08/2020(UTC), on 28/08/2020(UTC), on 20/09/2020(UTC)
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 829 time(s) in 525 post(s)
Hi. Thanks! Very much! "equrep() function supports variables/functions replacements now." Any example about what that means? Also, I see that this error persists: Best regards. Alvaro.
Hello Alvaro! Originally Posted by: Razonar Also, I see that this error persists: Yes, this is a main reason why I can't release stable version of SMath Studio now. I'm working on this issue right now. Best regards.
Originally Posted by: Razonar "equrep() function supports variables/functions replacements now."
Any example about what that means ? Can you show an application of it ? An image is good enough. Thanks ... Jean
Originally Posted by: Jean Giraud Originally Posted by: Razonar "equrep() function supports variables/functions replacements now."
Any example about what that means ? Can you show an application of it ? An image is good enough. Thanks ... Jean Hi Jean. Here: Applications for equrep: expression isolation and laplace transform.Best regards. Alvaro.
on 28/08/2020(UTC), on 29/08/2020(UTC)
Originally Posted by: Jean Giraud Can you show an application of it ? An image is good enough. Thanks ... Jean
Just to make it clear: equrep() function is not something I'm spending time on to create/support/improve. This function appeared as a demo of the updated symbolic core of SMath Studio. This function is an interface to the new functionality. You can use it or not, but it demonstrates possibilities of the symbolic simplifications SMath Studio provides. Unfortunately it has at least one issue which is hard to fix. I'm doing my best to remove a bug, but if it will be too hard maybe I will revert my changes and use stable (which is used in latest stable version of the application) symbolic core again. So it is not about equrep() function it is about core of the program, its performance, possibilities, behaviors etc. If you are remember, all the calculations in SMath Studio goes through symbolic optimization, so it is pretty important. Best regards.
on 29/08/2020(UTC), on 29/08/2020(UTC), on 29/08/2020(UTC), on 30/08/2020(UTC)
Thanks Alvaro ... always there in Smath Community ! BTW Andrey, if/else, if/otherwise have not been observed detrimental in timing in general applications. For this application [Julia], timing kills Smath ... Oh ! OK, my Win 7 1.66 GHz is steam engine. What about your latest Beta SS 7542 ? Thanks ... Jean Pattern Julia Set [PUBLISH].sm (173kb) downloaded 27 time(s).
Maybe it is a bug maybe intended I don't know; On 7542 for underlined text regions, spaces are not underlined. No problem for letters, numbers, punctuations, etc. Writer regions don't have this issue.
I can't switch on/off any more the border of image regions (and also fo Maxima draw regions) in 7542. In 7251 this still works. It also works for documents produced in 7542. Edited by user 09 September 2020 18:15:20(UTC)
Originally Posted by: overlord Maybe it is a bug maybe intended I don't know; On 7542 for underlined text regions, spaces are not underlined. No problem for letters, numbers, punctuations, etc. Writer regions don't have this issue.
Thank you! Fixed.
Originally Posted by: mkraska I can't switch on/off any more the border of image regions (and also fo Maxima draw regions) in 7542. In 7251 this still works. It also works for documents produced in 7542. I can't reproduce this issue locally. Please could you upload a files (one with correct behavior and another with incorrect)?
I attach two files. The first one is created in 7542. No matter what I do in the contex menu, the border can't be switched off. Neither is there a change in the GUI, nor is the xml attribute changed. If I load this file in 7251, then I can switch off the border, this is both visible on the canvas and in the xml entry. Once I save that (second file), this can be opened by 7542 and the change is respected. And you guess it, the border can't be switched on again. Thus, actually there is no wrong file, just wrong GUI behaviour. 7542 displays existing files correctly. Just no access to this one setting. I leave out the maxima draw region, as this might prevent reproduction without maxima installation. border 7542.sm (8kb) downloaded 16 time(s). border 7542 then 7251.sm (8kb) downloaded 19 time(s). |
Originally Posted by: mkraska I attach two files. The first one is created in 7542. No matter what I do in the contex menu, the border can't be switched off. Neither is there a change in the GUI, nor is the xml attribute changed. If I load this file in 7251, then I can switch off the border, this is both visible on the canvas and in the xml entry. Once I save that (second file), this can be opened by 7542 and the change is respected. And you guess it, the border can't be switched on again. Thus, actually there is no wrong file, just wrong GUI behaviour. 7542 displays existing files correctly. Just no access to this one setting. I leave out the maxima draw region, as this might prevent reproduction without maxima installation. border 7542.sm (8kb) downloaded 16 time(s). border 7542 then 7251.sm (8kb) downloaded 19 time(s). Thank you very much. Fixed now. There is one issue with the plug-in: invalidation of the region is not requested after menu item usage (it must be done by plug-in) so borders will be visually switched only after region redrawn, f.e. after scrolling or focus in/out. Best regards.
Originally Posted by: Razonar Hi. Thanks! Very much! "equrep() function supports variables/functions replacements now." Any example about what that means? Also, I see that this error persists: Best regards. Alvaro. Issue is fixed in the latest stable version I have just published. equrep() made less powerful, so it will leave an equation as is in cases where error is possible. Like your example. This is temporary solution but it is required to continue development without serious stoppers. In future I will continue working to make symbolic engine more smart. Best regards.
This also seems to be the cause for delayed re-draw after editing operation (you have to get focus off the image to see the changes). Very valuable hint! Filed in the bug tracking system as SS-4640 |
... I post that question because interpret that then equrep works replacing f by sin in this example: "equrep(3+f(x),f,sin)=3+f(x)" but now I see that the correct way is "equrep(3+f(x),f(a),sin(a))=3+sin(x)" Here my attempt to convert an expression with operators to an expression with binary or unary functions only _to_expr.sm (52kb) downloaded 16 time(s). _to_expr.pdf (224kb) downloaded 23 time(s).Best regards. Alvaro.
Rematch ... It's seems to work now. num2expr.sm (40kb) downloaded 13 time(s). num2expr.pdf (177kb) downloaded 23 time(s).
