Offline ioncube
#1 Posted : 17 November 2020 10:57:44(UTC)
ioncube
Pakistan
Was thanked: 2 time(s) in 2 post(s)
I want to using solve function for a simple arithmetic equation. But one of the value is an array so I must have array of answers. I am unable to achieve this using solve & maple.solve
As the last resort I had to solve the equation separately which is both boring & not dynamic. The equation has units...
Page1.sm (185kb) downloaded 7 time(s).
Offline uni
#2 Posted : 17 November 2020 11:31:26(UTC)
uni
Russia ☭ forever
Viacheslav N. Mezentsev
Offline ioncube
#3 Posted : 17 November 2020 13:14:29(UTC)
ioncube
Pakistan
Thanks for the solution. Can you please explain why we need to vectorize (above arrow) the last statement?
Secondly I cannot add units to x in the function developed st_mass? My version is 0.99 (6671)
Offline uni
#4 Posted : 17 November 2020 13:20:34(UTC)
uni
If the function uses a scalar and you substitute a vector of values, then you need to either use a loop over the elements of the vector, or the vectorization operator.
Try to multiply x by 1 and replace 1 with units.
And I think that the maple() function is not needed here, an ordinary solve() should handle it.
Edited by user 17 November 2020 13:25:39(UTC)  | Reason: Not specified
Russia ☭ forever
Offline ioncube
#5 Posted : 17 November 2020 14:23:15(UTC)
ioncube
Pakistan
Per my experience maple.solve handles units far better... However still I am not able to reproduce your results.
Sheet is attached, may be my version is old?
Page1.sm (175kb) downloaded 6 time(s).
Offline uni
#6 Posted : 17 November 2020 14:29:19(UTC)
uni
Keep in mind that the function maple() doesn't know anything about units at all. The function uses a special trick to ignore them in its work.
Try now
Page1 (uni).sm (176kb) downloaded 12 time(s).
Page1 (uni).pdf (381kb) downloaded 9 time(s).
Edited by user 17 November 2020 14:33:02(UTC)  | Reason: Not specified
Russia ☭ forever
Offline ioncube
#7 Posted : 17 November 2020 15:51:32(UTC)
ioncube
Pakistan
Originally Posted by: uni Go to Quoted Post
Ok I made a typo fault. Everything OK now THNX
Edited by user 17 November 2020 16:10:57(UTC)  | Reason: Not specified
#8 Posted : 17 November 2020 18:31:50(UTC)
Here is Engineer style ... no need for Maple, just native Smath
Attached SS 6179 ... some volunteer to make it unit kg/s
Ioncube Otherwise.sm (21kb) downloaded 16 time(s).
Offline Razonar
#9 Posted : 18 November 2020 06:47:29(UTC)
Razonar
Uruguay
Was thanked: 830 time(s) in 526 post(s)
Hi. I guess that the problem is that kw just like "kw" both in lowercase isn't an unit, but it is kW. To know the name of an unit you have the coup icon for insert one in the toolbar.
In the attached using kW instead kw, maple don't needs units manipulation, but SMath's roots needs.
Page1 (uni).pdf (414kb) downloaded 9 time(s).
Page1 (uni).sm (178kb) downloaded 13 time(s).
on 18/11/2020(UTC)
#10 Posted : 18 November 2020 15:17:56(UTC)
... forget units, reconciliate as you wish in the solve bloc & Table
Ioncube Otherwise.sm (29kb) downloaded 4 time(s).
