Hi, How can I equate power of range to the following? How can we solve this error, anything power should be 1. When a range is square, the return answer is total of square value. Page5.sm (10kb) downloaded 2 time(s).Edited by user 21 January 2021 21:10:36(UTC)
Originally Posted by: davidlimtw How can I equate power of range to the following? How can we solve this error, anything power should be 1.
As you evaluate over a vector, use the vectorize operator.
I tried to vectorize the following. What have I done wrong? Page6.sm (6kb) downloaded 3 time(s).
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 829 time(s) in 525 post(s)
Originally Posted by: davidlimtw I tried to vectorize the following. What have I done wrong? .... Hi. There the problem is 0^0, it is undefined, at least in SMath environment, and probably it's the best choice: return an error if appear. That for the vectorization. About w^0, without vectorization, seems that SMath try to do a scalar product, like in w^2. Remember that a^0 = 1 for a <> 0 it's by definition, not by any theorem. Best regards. Alvaro. Edited by user 21 January 2021 22:42:56(UTC)
Delete thehat are you trying to do? Everything is defined, yet, you have a range for the answer. Are you looking to plot?
I am trying to plot and integrate, but no luck Page4.sm (21kb) downloaded 3 time(s).
I just need to put a very small values instead of zero.
Originally Posted by: davidlimtw I am trying to plot and integrate, but no luck
No luck because NO function, always plot the function you want to integrate. Pure suggestion attached ... Jean Page4.sm (36kb) downloaded 6 time(s).
For inspiration. Heat Capacity Function1.sm (21kb) downloaded 26 time(s).Let me know if you cannot open it. Jean had an issue when I posted it yesterday
Originally Posted by: ElSid Let me know if you cannot open it. Jean had an issue when I posted it yesterday Oh ! Elsid ... wrong format. Our Win systems are not companions ! Take care ... Jean
