Offline hanskl
#1 Posted : 26 May 2021 02:10:14(UTC)
hanskl
Norway
Was thanked: 7 time(s) in 5 post(s)
Hi!
When I want to plot text/strings, I add mat(1;5) to my graph. Strings usually has top left justification.
Is it possible to set justification as the sixth element of the matrix?
Offline hanskl
#2 Posted : 26 May 2021 09:22:32(UTC)
hanskl
Norway
Originally Posted by: hanskl Go to Quoted Post
Is it possible to set justification as the sixth element of the matrix ?
No need AFAIK.
Hello Jean,
Take a look at the attached image. I want C to have top right justification, and B bottom right. I could just offset the coordinates for a quick fix, but when I change the zoom level that will not work.
Best regards,
#3 Posted : 26 May 2021 15:11:04(UTC)
Hello Jean,
Best regards,
For fixed rotation, you can get inspired from the attached.
Smath is not a CAD, but from little it does so much.
This W Truss originates from Ioan [SS 5346 ?]
End result from multiple collaboration [Alyles, Carlos, Jean].
Next from you: *.sm document.
Utilities XY [Draw Truss Labels ZOOMED mode].sm (27kb) downloaded 39 time(s).
Offline hanskl
#4 Posted : 26 May 2021 16:39:47(UTC)
hanskl
Norway
Jean,
Your example seems to work well when zooming out. When zooming in the labels starts getting further appart fram the drawing.
I was hoping maybe this was something the developers could incorporate in an upcoming release.
Best regards,
Offline hanskl
#5 Posted : 26 May 2021 20:24:37(UTC)
hanskl
Norway
You are asking a CAD functionality that does not have much interest.
This triangle has some curious relationship.
Most probably each figure will have more surprises + rotation.
What is the interest of zooming a triangle ?
That one, you can zoom/rotate at will for [Area/Perimeter/CG]
[Area/Perimeter/CG] for any figure of XY vertices.
Where are you in your design ? ... Jean.
Jean,
I was just puzzling around with trigonometry. I never seem to remember the trigonometric relationships, so rather than googling 'trigonometric functions' all the time, I figured it would be fun to try to make something in SMath.
Attached is the "project" I was fooling around with. I tried to plot an angle (L) in all the corners that were 90°, but because of the significant round-off errors I skipped that part.
Best regards,
Trigonometry.sm (40kb) downloaded 23 time(s).
Offline overlord
#6 Posted : 26 May 2021 21:42:27(UTC)
Turkey
This is a very good example.
Nice job, kudos to your project.
Offline hanskl
#7 Posted : 26 May 2021 22:16:54(UTC)
hanskl
Norway
Thank you, far too kind!
Best regards,
Offline hanskl
#8 Posted : 27 May 2021 00:54:42(UTC)
hanskl
Norway
Your zoomed triangle is pure success from brute force refactoring.
Sorry for the 5 hours power failure from unusual strong wind.
Thanks for this nice project ... Jean
Trigonometry.sm (50kb) downloaded 12 time(s).
I guess zooming in and out on the plot could be avoided by resizing the triangle within the plot.. and that way shifting/aligning the labels manually will work just fine.
Best regards,
#9 Posted : 27 May 2021 14:04:45(UTC)
Last brick in the wall for that one.
Medians [med] approximate, not from calculations.
More maths added for convenience.
Thanks for that superb Classroom ... Jean
Utilities XY [Draw ZOOM Triangle].sm (21kb) downloaded 19 time(s).
Offline hanskl
#10 Posted : 28 May 2021 13:10:15(UTC)
hanskl
Norway
Jean,
Very interesting! Thanks for the insight.
Best regards,
#11 Posted : 28 May 2021 16:57:10(UTC)
... added rotation of a new triangle.
Take care ... Jean
Utilities XY [Draw ZOOM Triangle] Copy.sm (48kb) downloaded 15 time(s).
