Hi all, I have some custom functions implemented on snippets. I have different ones which i recall when i open a blank smath sheets. It used to work well but in version 0.99 (build:7822), in fact since the version just before that, there's some type of exception thrown when inserting the snippet. If i click on continue, everything seems to work ok in the sheet and i do not get the message anymore (unless i try to insert a new snippet) Thanks in advance, Find also attached the full exception message ExceptionMessage_SnippetsBug.txt (12kb) downloaded 8 time(s).Edited by user 04 June 2021 13:30:01(UTC)
Reproduced. Will fix asap. Thank you!
Hello everyone, maybe you could solve the problem, the same thing happens to me every time I enter a snippet I created.
Joined: 11/01/2018(UTC) Posts: 134 Location: Wisconsin Was thanked: 62 time(s) in 39 post(s)
Greetings,
If you are still on v0.99 and would like to avoid this error, there is a work-around: Delete the entry in the "Title" field (or the title filed altogether)
1) Navigate to the *.sm files that contain the snippets (e.g., .../Programs/SMath Studio/snippets) 2) Edit file with a Text Editor 3) Remove the metadata entry of <Title> </Title> 4) Save file 5) Relaunch SMath
- Kenny Lemens, P.E. ᵂᴵ |
Thank you Kenny, Andrey just fixed it in the subsequent versions, so it works ok for me since then. Edited by moderator 01 December 2022 23:18:14(UTC)
| Reason: marked as FIXED
