SMath Studio Forum
Questions
Split Areas(Polygons convex and concave) by lines
Joined: 28/08/2014(UTC) Posts: 1,371 Was thanked: 833 time(s) in 527 post(s)
Originally Posted by: cleisonmanrique ... I guess we can not use the same matrix of contour point to get the area and de center of mass ... Or am I wrong ? Hola Manrique. If I'm not wrong, in the Martin's worksheet, the area is A(C) and the center of mass, which he call CG = [S.x(C)/A(C), S.y(C)/A(C)] Best regards. Alvaro.
You can try to use chunk() from PolyProperties. For a generic oriented line, you have to rotate the polygon using the line orientation, apply the chunk() function about an axis, and rotate back the polygon. Edited by user 26 May 2023 14:40:11(UTC)
SMath Studio Forum
Questions
