SMath Studio Forum
Download SMath Studio
Nightly builds
Nightly build: SMath Studio 0.96.5146 (02 February 2014)
Nightly build: SMath Studio 0.96.5146 available Important notes - Custom Regions plug-ins created for previous versions of SMath Studio will not work. Please contact developers of such plug-ins and ask them to update plug-ins. Sorry for the inconvenience!
In the class inherited from IPluginCustomRegion change: Code:bool IPluginCustomRegion.IsCurrentClipboardSupported
get
IDataObject iData = Clipboard.GetDataObject();
return iData.GetDataPresent(DataFormats.UnicodeText);
to: Code:string[] IPluginCustomRegion.SupportedClipboardFormats
get { return new string[] { DataFormats.UnicodeText }; }
It is also required to add the following field (where tag name for your region must be specified instead of "combobox" text): Code:string IPluginCustomRegion.TagName
get { return "combobox"; }
In the class inherited from RegionBase signatures of the methods: Code:public override bool Copy()
public override bool Paste()
changed to: Code:public override bool Copy(IClipboardManager clipboard)
public override bool Paste(IClipboardManager clipboard)
So, you don't need to use System.Windows.Forms.Clipboard anymore. Just use clipboard object from method argument.
- No official portable version will be available for this release.
Download Edited by user 02 February 2014 16:42:31(UTC)
on 02/02/2014(UTC), on 02/02/2014(UTC), on 02/02/2014(UTC), on 02/02/2014(UTC), on 02/02/2014(UTC), on 03/02/2014(UTC), on 03/02/2014(UTC)
Andrey, thanks for the update.
For testing I recommend to use the Linux version. As usual it can be used under Windowsm as portable version when an empty file "portable.version" is added to the installation directory. Then you can keep all extensions and settings separate from your standard installation.
An unofficial portable version will certainly be available, depending on upgrade progress of custom regions.
Unfortunately, the Maxima plugin is affected by API changes as well, even if not providing a custom region, access to the insert menu or custom windows seem to be problematic as well. |
FYI: I've just added a spoiler about what to be done to update Custom Regions related plug-ins.
The following plug-ins updated to support SMath Studio 0.96.5146: - Combobox Region
- Checkbox Region
- Modeller Region
- Export to PDF
Originally Posted by: smath Any hint on how to use it? How about gallery example passwords? Might be really interesting and powerfull stuff... |
SMath Studio Forum
Nightly builds
