Offline rsdias
#1 Posted : 17 November 2022 13:27:15(UTC)
rsdias
Brazil
I started using the Smath program a little while ago and I'm having a problem that I believe is because I don't know how the software works with physical units.
My problem is the following, I have a variable ton:= 6.1538 us (micro seconds), but when I do Ton^2 the result does not appear in the micro seconds unit and it stays with s^2 us unit, I don't understand how to leave it alone in micro seconds, and with that the calculation is also not correct in a formula that uses this variable ton^2, could someone tell me how this question of units works please. Thanks in advance for your attention.
#2 Posted : 17 November 2022 16:20:18(UTC)
Sounds like you have a non-physical equation.
If you have a = 1 m and A = a^2, then I would expect A being 1 m^2. So your physics must be very special.
Offline Kenny Lemens
#3 Posted : 17 November 2022 16:26:03(UTC)
Kenny Lemens
United States
Greetings!
By default, 「's」 is the base unit in SMath (and thus, the default unit of time); any calculation in terms of time will report in seconds. If you want to review your answer in microseconds, you can insert microseconds in the placeholder at the right of your equation to override the default units.
Clicking on your equation, you should notice a ▮ appear, just type the unit 「'μs」 and you will see your desired result:
Hope this helps you,
Kenny Lemens, P.E. ᵂᴵ
P.S. you mentioned ton and Ton in your post, be aware SMath is Case-Sensative; that is tonTon
Offline rsdias
#4 Posted : 17 November 2022 17:23:12(UTC)
rsdias
Brazil
Thanks for the guidance, using microseconds as the unit, everything worked out fine. Thanks.
