Hello I can't install several plugins, see attached image Best Regards Carlos
Hello Carlos, I have no such problem. Hope somebody will help you. |
Hello NDTM
Thank you very much, I also hope that someone can solve the problem, which seems to be something that always occurs in updates.
It depends on the implementation of the interfaces between the program and the plugins, although I'm not sure why sometimes the plugin don't work for someone; usually is enough to recompile the plugin, sometime the code has also to be updated. |
