SMath Studio Forum
Questions
Type conversion error while solving a system of ODEs
Joined: 27/01/2023(UTC) Posts: 30 Was thanked: 3 time(s) in 3 post(s)
Thanks for creating such a helpful software, I have a problem solving the attached system of ODEs it keeps saying Type conversion error on Adams function please help. Gyroscope.sm (10kb) downloaded 10 time(s).Edited by user 27 January 2023 16:09:37(UTC)
Joined: 28/08/2014(UTC) Posts: 1,367 Was thanked: 826 time(s) in 523 post(s)
Hi. You can't build matrices A and B that way, but you can with stack and augment. BTW, it seems that the interval where it finds the solution is the [0,1] giving overflow error for 1000 steps and the interval [0,5] Best regards. Alvaro.
Oh okay,,, i didnt know that, Thank you so much
... plot enough points to view the system response. Cheers ... Jean. Gyroscope.sm (34kb) downloaded 8 time(s).
Originally Posted by: Oichi Thank you so much In the same concept of parametric ODE. Cheers ... Jean. ODE Parametric.sm (20kb) downloaded 8 time(s).
How can I get these matlab solvers
Originally Posted by: Oichi How can I get these matlab solvers The mwode* functions are part of the plugin Matlab Runtime Library; it ask you to install when you open a worksheet that contains these functions or you can download manually from the extensions manager. Edited by user 28 January 2023 12:47:51(UTC)
Originally Posted by: Davide Carpi Originally Posted by: Oichi How can I get these matlab solvers The mwode* functions are part of the plugin Matlab Runtime Library; it ask you to install when you open a worksheet that contains these functions or you can download manually from the extensions manager. Thank you so much
I have the plugin of Matlab runtime library and it has no ode solvers of matlab
Originally Posted by: Oichi I have the plugin of Matlab runtime library and it has no ode solvers of matlab I have all 'mw...' from native Smath 6179. that was installed from the option installerrather than from plugins. Does it suggest to re-install your version ?
Originally Posted by: Oichi I have the plugin of Matlab runtime library and it has no ode solvers of matlab It may not work on windows 64-bit or linux/mono systems. There is a trick for windows however. Link to Extension PageRegards
Originally Posted by: overlord Originally Posted by: Oichi I have the plugin of Matlab runtime library and it has no ode solvers of matlab It may not work on windows 64-bit or linux/mono systems. There is a trick for windows however. Link to Extension PageRegards I did everything written in that link but I still can't find those matlab functions
Originally Posted by: Jean Giraud Originally Posted by: Oichi I have the plugin of Matlab runtime library and it has no ode solvers of matlab I have all 'mw...' from native Smath 6179. that was installed from the option installerrather than from plugins. Does it suggest to re-install your version ? I don't understand you, can you provide further explanation
Originally Posted by: Oichi I did everything written in that link but I still can't find those matlab functions Did you also made Solver.exe 32bit? When uni wrote that information, SMath was not splitted to Solver and Writer. Run these two commands as administrator. Code:CorFlags.exe /32bit+ Solver.exe
CorFlags.exe /32bit+ SMathStudio_Desktop.exe
And check if they are 32bit signed, output should look like this. Code:C:\Program Files (x86)\SMath Studio> CorFlags.exe Solver.exe
Microsoft (R) .NET Framework CorFlags Conversion Tool. Version 4.8.9037.0
Copyright (c) Microsoft Corporation. All rights reserved.
Version : v2.0.50727
CLR Header: 2.5
PE : PE32
CorFlags : 0x3
ILONLY : 1
32BITREQ : 1
32BITPREF : 0
Signed : 0
If method above doesn't work, use this new version of CorFlags. CorFlags.zip (100kb) downloaded 6 time(s).I have personally tried, it does work.
Originally Posted by: overlord Originally Posted by: Oichi I did everything written in that link but I still can't find those matlab functions Did you also made Solver.exe 32bit? When uni wrote that information, SMath was not splitted to Solver and Writer. Run these two commands as administrator. Code:CorFlags.exe /32bit+ Solver.exe
CLR Header: 2.5
PE : PE32
CorFlags : 0x3
ILONLY : 1
32BITREQ : 1
32BITPREF : 0
Signed : 0
If method above doesn't work, use this new version of CorFlags. CorFlags.zip (100kb) downloaded 6 time(s).I have personally tried, it does work. Yes, Thanks ^^ It finally worked. I needed to do that solver corflags
SMath Studio Forum
Questions
