SMath Studio Forum
Bugs & Problems
Cannot launch SMathStudio_Desktop.exe versions 1.0.x from Linux desktop file
I run the mono version of Smath Studio on KDE Linux. I attempted to update version 0.99.7822 but all more recent mono versions will not launch from the desktop file (but I can run them from the terminal line using 'sudo mono SMathStudio_Desktop.exe'.) My desktop file is set to run SMathStudio_Desktop.exe as root; this works fine for version 0.99.7822. Also, it appears that recent versions require a version of .NETFramework that Mono does not provide. So far, the 2021-era version is sufficient for me; I just wanted to register these problems. And thanks! I am keeping calm and calculating.
Originally Posted by: RAMDass I run the mono version of Smath Studio on KDE Linux. I take you are using KDE Neon, which is debian based. Debian based distros have a mono bug, caused by glibc. Not only SMath, some mono programs don't work also without sudo. So far only debian or ubuntu based distro I could make all mono programs run without sudo is MXLinux (ahs). It has a linux kernel v6+ and an updated glibc also. Maybe this is the reason why it works and LTS versions are not. I will download your OS and check in a VM if this is the reason. And for desktop file issue, file/script below is what I use. I use a dark theme but SMath doesn't look good with it. Script also change theme to a light one just for SMath. Regards smathstudio_desktop_mono.tar.gz (1kb) downloaded 3 time(s).Code:#!/bin/sh
HERE="$(dirname "$(readlink -f "${0}")")"
cd "${HERE}"
GTK2_RC_FILES=/usr/share/themes/Raleigh/gtk-2.0/gtkrc exec mono "${HERE}//SMathStudio_Desktop.exe" "$@"
SMath Studio Forum
Bugs & Problems
