Offline xlguru
#1 Posted : 21 February 2023 19:39:04(UTC)
xlguru
Bahrain
My Setup=
Windows 7
4Gb RAM
64 Bit
I get the following:
Solver has Stopped Working
Then get 2 Options
Close the Program
Debug the Program
Please Advice What to Do ?
ABA
#2 Posted : 21 February 2023 23:55:28(UTC)
It happens on program start? After loading a worksheet?
Offline xlguru
#3 Posted : 22 February 2023 06:46:33(UTC)
xlguru
Bahrain
It Happens on Program Start.
for me it is a Puzzle ...
Thanks for trying to Help.
ABA
#4 Posted : 22 February 2023 20:53:19(UTC)
As first step you can choose the "Debug" option and see if it returns a stack trace (list of code functions involved to some degree with the issue). If it happens copy and paste it here.
As second step, with SMath closed, open a explorer window and in the address bar type
Code:
%appdata%
then press return.
There should be a "SMath" folder, rename it as something else (f.e. SMath_backup) and try to start the program again.
Offline xlguru
#5 Posted : 22 February 2023 21:11:02(UTC)
xlguru
Bahrain
Thanks Again
When I choose "Debug" nothing Happens ...?!
ABA
Offline Kenny Lemens
#6 Posted : 22 February 2023 23:12:49(UTC)
Kenny Lemens
United States
Greetings,
Just so we are all on the same page, what scenario are you currently experiencing?
  1. This the first time using SMath (Just downloaded/installed it) and it does not work
  2. I have been using SMath, and today it just stopped working
    1. Were you informed "New Version Available" and you clicked to install?
    2. Did you just install a new plugin?
    3. Did you attempting adding/changing settings in the Program Folders (e.g., Units.xml)?
If possible, please list the SMath Version you are currently using/installed; answers may change depending if you are using the latest stable version, or a beta version, or a version before v1.00
Kenny Lemens, P.E. ᵂᴵ
Offline xlguru
#7 Posted : 22 February 2023 23:45:18(UTC)
xlguru
Bahrain
My case is : This the first time using SMath (Just downloaded/installed it) and it DOES NOT WORK
Which Version ?: This is the File I downloaded recently for Installation
(Can not Run it to get more Details)
Version 1.0.8348 - Stable (released at 11.9.2022)
Kindly note I have used previous versions of Smath and they worked Nicely
Thanks for your Effort .. Warm Regards ... ABA
#8 Posted : 23 February 2023 12:23:22(UTC)
Ok, it was worth to give it a try.
Have you tried this?
Code:
%appdata%
then press return.
Offline xlguru
#9 Posted : 23 February 2023 13:16:56(UTC)
xlguru
Bahrain
WOW ... It Worked ...WOW
THANK YOU VERY MUCH
Regards .... ABA
#10 Posted : 23 February 2023 14:38:21(UTC)
Very good, then it was some extension messing up.
Since you are a fresh user you can probably delete safely the old folder (it contains the extensions downloaded for your account and their settings, as well as f.e. the output data of built-in file writing functions)
Edited by user 23 February 2023 21:12:40(UTC)  | Reason: Typo, marked as solved
Offline xlguru
#11 Posted : 23 February 2023 15:11:13(UTC)
xlguru
Bahrain
Thank You for the Follow-Up, you must be having
a Deep and Clear understanding of the Product.
May I suggest you write a book about Smath.
