SMath Studio Forum
Questions
Generating Control Valve Curve using SMATH
Joined: 04/12/2017(UTC) Posts: 61 Was thanked: 2 time(s) in 2 post(s)
I have Chinese valves where from nameplate I can get Cv @100% open & that its Equal%. Now I generated a spreadsheet model which is fairly simple & then used 'Goal Seek' feature to iterate values such that I get stated Cv at 100% opening. I am uploading procedure that I followed (this document also has a small video file) I am also attaching spreadsheet file as well. External server zip file: https://www.mediafire.co...urve+Generation.zip/fileNow how can I do this in SMATH Studio? I mean construct in such a way that I change one value such until I get required CV at 100% as well as each interval increment is equal percentage Characteristic Curve Generation.zip (2,450kb) downloaded 9 time(s).
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 829 time(s) in 525 post(s)
Originally Posted by: ioncube I have Chinese valves where from nameplate I can get Cv @100% open If your valve would be Fisher Controls, you should be able to reach the catalog page c/w cv/% opening + more valve data. This document fits = % & quick opening. As a separate Smath document, I have the Fisher valve sizing procedure, including the pulp stock. Cheers ... Jean. Fisher.sm (35kb) downloaded 16 time(s).
Extremely thanks Razonar & Jean
SMath Studio Forum
Questions
