Joined: 22/02/2023(UTC) Posts: 34 Location: Seoul Was thanked: 1 time(s) in 1 post(s)
i want to solve below problem m, ka, pa i try to solve this problem but i can't get result. 20230614_lateral earth pressure.sm (101kb) downloaded 11 time(s).Thanks in advance
Joined: 28/08/2014(UTC) Posts: 1,367 Was thanked: 826 time(s) in 523 post(s)
Hi. Maybe the attached helps, but's hard to know. At the eqn 16 I count two open [ and only one closed ]. 20230614_lateral earth pressure.sm (75kb) downloaded 21 time(s).Best regards. Alvaro.
Joined: 26/07/2022(UTC) Posts: 37 Location: UK Was thanked: 24 time(s) in 21 post(s)
Originally Posted by: StvMath My suggested solution is in the attached. Get more accurate solutions from roots(,,,) LateralEarthPressure.sm (14kb) downloaded 7 time(s).
