Offline ndtma
#1 Posted : 07 September 2023 18:34:24(UTC)
ndtma
Sri Lanka
I remember there were some useful posts to find the positions in an array
satisfying defined conditions.
Another approach is attached.
Array_Pos2.sm (16kb) downloaded 15 time(s).
Edited by user 07 September 2023 18:36:31(UTC)  | Reason: Not specified
thanks 4 users thanked ndtma for this useful post.
on 07/09/2023(UTC),  on 07/09/2023(UTC),  on 08/09/2023(UTC),  on 07/04/2024(UTC)
Offline alyles
#2 Posted : 08 September 2023 20:59:13(UTC)
alyles
United States
To expand on this concept further, I generally avoid using augment/stack functions with vectors of indeterminate size. The reason being that there is generally quite a bit of overhead in using those functions when it comes to execution time. I propose an alternative method shown here. Firstly we perform the test on the input matrix to determine the size of the result vector and location of results in input matrix. Then we instantiate the result vector and fill it in. To demonstrate the difference in execution I've also created a 100x100 input vector and timed the execution of both algorithms. The execution time difference becomes more apparent the larger the input matrix becomes.
Array_Pos2.pdf (138kb) downloaded 7 time(s).
Array_Pos2.sm (45kb) downloaded 19 time(s).
thanks 3 users thanked alyles for this useful post.
on 08/09/2023(UTC),  on 08/09/2023(UTC),  on 09/09/2023(UTC)
