Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 339 Was thanked: 26 time(s) in 25 post(s)
EK45 was Deified by Mathematica Working code included. Jean Rocket-s-Euler.sm (123kb) downloaded 5 time(s).
Joined: 26/07/2022(UTC) Posts: 35 Location: UK Was thanked: 22 time(s) in 19 post(s)
Your RK does work! Your Euler doesn't because you have defined the acceleration term to have two input variables, but only call it with one in the Euler routine! Rocket-s-Euler-RK-full.sm (90kb) downloaded 13 time(s).Edited by user 31 December 2023 23:18:57(UTC)
1 user thanked StvMath for this useful post.
Originally Posted by: StvMath Your RK does work! Your Euler doesn't because you have defined the acceleration term to have two input variables, but only call it with one in the Euler routine! Tanks! Send me please the corrected file.
Originally Posted by: OchkovVF Originally Posted by: StvMath Your RK does work! Your Euler doesn't because you have defined the acceleration term to have two input variables, but only call it with one in the Euler routine! Tanks! Send me please the corrected file. I've now added the corrected file to my earlier reply.
