I would like to confirm this bug. Steps to reproduce: open new file, write random expression, copy it and try to paste (ctrl+c followed by ctrl+v). Results in crash. I am using: dev-lang/mono-3.2.8 smath 0.97 build 5154 on funtoo linux Here is crash message: Quote: System.ObjectDisposedException: The object was used after being disposed. at System.IO.MemoryStream.CheckIfClosedThrowDisposed () [0x00000] in <filename unknown>:0 at System.IO.MemoryStream.Read (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in <filename unknown>:0 at System.Xml.XmlInputStream.Initialize (System.IO.Stream stream) [0x00000] in <filename unknown>:0 at System.Xml.XmlInputStream..ctor (System.IO.Stream stream) [0x00000] in <filename unknown>:0 at (wrapper remoting-invoke-with-check) System.Xml.XmlInputStream:.ctor (System.IO.Stream) at System.Xml.XmlStreamReader..ctor (System.IO.Stream input) [0x00000] in <filename unknown>:0 at (wrapper remoting-invoke-with-check) System.Xml.XmlStreamReader:.ctor (System.IO.Stream) at System.Xml.XmlTextReader..ctor (System.IO.Stream input) [0x00000] in <filename unknown>:0 at SMathFileType.SMathFileType. (System.IO.Stream , System.Collections.Generic.List`1 , SMath.Control.FileContext ) [0x00000] in <filename unknown>:0 at SMath.Control.DataFiles.OpenFileType (System.IO.Stream stream, SMath.Control.Worksheet worksheet, SMath.Control.FileContext context) [0x00000] in <filename unknown>:0 at SMath.Control.ClipboardManager.GetRegions (SMath.Control.Worksheet worksheet, Int32 topCorrection) [0x00000] in <filename unknown>:0 at SMath.Control.Worksheet. (System.String ) [0x00000] in <filename unknown>:0 at SMath.Control.Worksheet.Insert (System.String value) [0x00000] in <filename unknown>:0 at SMath.Control.WorksheetControl.OnKeyDown (System.Windows.Forms.KeyEventArgs e) [0x00000] in <filename unknown>:0 at System.Windows.Forms.Control.ProcessKeyEventArgs (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0 at System.Windows.Forms.Control.ProcessKeyMessage (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0 at System.Windows.Forms.Control.WmKeys (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0 at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0 at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0 at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0 at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam) [0x00000] in <filename unknown>:0
Unhandled Exception: System.ArgumentException: A null reference or invalid value was found [GDI+ status: InvalidParameter] at System.Drawing.GDIPlus.CheckStatus (Status status) [0x00000] in <filename unknown>:0 at System.Drawing.Graphics.GdipMeasureString (IntPtr graphics, System.String text, System.Drawing.Font font, System.Drawing.RectangleF& layoutRect, IntPtr stringFormat) [0x00000] in <filename unknown>:0 at System.Drawing.Graphics.MeasureString (System.String text, System.Drawing.Font font, Int32 width, System.Drawing.StringFormat format) [0x00000] in <filename unknown>:0 at (wrapper remoting-invoke-with-check) System.Drawing.Graphics:MeasureString (string,System.Drawing.Font,int,System.Drawing.StringFormat) at System.Windows.Forms.TextRenderer.MeasureTextInternal (IDeviceContext dc, System.String text, System.Drawing.Font font, Size proposedSize, TextFormatFlags flags, Boolean useMeasureString) [0x00000] in <filename unknown>:0 at System.Windows.Forms.TextRenderer.MeasureText (System.String text, System.Drawing.Font font, Size proposedSize, TextFormatFlags flags) [0x00000] in <filename unknown>:0 at System.Windows.Forms.ToolStripItem.OnParentChanged (System.Windows.Forms.ToolStrip oldParent, System.Windows.Forms.ToolStrip newParent) [0x00000] in <filename unknown>:0 at System.Windows.Forms.ToolStripItem.set_Parent (System.Windows.Forms.ToolStrip value) [0x00000] in <filename unknown>:0 at (wrapper remoting-invoke-with-check) System.Windows.Forms.ToolStripItem:set_Parent (System.Windows.Forms.ToolStrip) at System.Windows.Forms.ToolStripItemCollection.Remove (System.Windows.Forms.ToolStripItem value) [0x00000] in <filename unknown>:0 at System.Windows.Forms.ToolStripItem.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0 at System.Windows.Forms.ToolStripDropDownItem.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0 at System.Windows.Forms.ToolStripMenuItem.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0 at System.ComponentModel.Component.Finalize () [0x00000] in <filename unknown>:0
Best regards, quert edit @ 28.06.14 I have downloaded newer build and there is change in crash behaviour. Smath now displays file save dialogue like before closing. smath 0.97 build 5283 Here is crash message: Quote: System.ObjectDisposedException: The object was used after being disposed. at System.IO.MemoryStream.CheckIfClosedThrowDisposed () [0x00000] in <filename unknown>:0 at System.IO.MemoryStream.Read (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in <filename unknown>:0 at System.Xml.XmlInputStream.Initialize (System.IO.Stream stream) [0x00000] in <filename unknown>:0 at System.Xml.XmlInputStream..ctor (System.IO.Stream stream) [0x00000] in <filename unknown>:0 at (wrapper remoting-invoke-with-check) System.Xml.XmlInputStream:.ctor (System.IO.Stream) at System.Xml.XmlStreamReader..ctor (System.IO.Stream input) [0x00000] in <filename unknown>:0 at (wrapper remoting-invoke-with-check) System.Xml.XmlStreamReader:.ctor (System.IO.Stream) at System.Xml.XmlTextReader..ctor (System.IO.Stream input) [0x00000] in <filename unknown>:0 at SMathFileType.SMathFileType. (System.IO.Stream , System.Collections.Generic.List`1 , SMath.Control.FileContext ) [0x00000] in <filename unknown>:0 at SMath.Control.DataFiles. (System.IO.Stream , SMath.Control.Worksheet , SMath.Control.FileContext ) [0x00000] in <filename unknown>:0 at SMath.Control.DataFiles.OpenFileType (System.IO.Stream stream, SMath.Control.Worksheet worksheet, SMath.Control.FileContext context) [0x00000] in <filename unknown>:0 at SMath.Control.ClipboardManager.GetRegions (SMath.Control.Worksheet worksheet, Int32 topCorrection) [0x00000] in <filename unknown>:0 at SMath.Control.Worksheet. (System.String ) [0x00000] in <filename unknown>:0 at SMath.Control.Worksheet.Insert (System.String value) [0x00000] in <filename unknown>:0 at SMath.Control.Worksheet. (System.String ) [0x00000] in <filename unknown>:0 at SMath.Control.Worksheet.Insert (System.String value) [0x00000] in <filename unknown>:0 at SMath.Control.WorksheetControl.OnKeyDown (System.Windows.Forms.KeyEventArgs e) [0x00000] in <filename unknown>:0 at System.Windows.Forms.Control.ProcessKeyEventArgs (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0 at System.Windows.Forms.Control.ProcessKeyMessage (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0 at System.Windows.Forms.Control.WmKeys (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0 at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0 at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0 at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0 at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam) [0x00000] in <filename unknown>:0
Best regards, quert Edited at by user 28 June 2014 17:29:05(UTC)
