Hi everyone, I came across to something strange for system of values. as you see in the attached, If I add a integer number for in powering numbers (just in powering numbers not in the other fields) Smath return 4 values and assume it as a fraction and power numerator and denominator separately. How can I tell it to consider the number just as a one value. is there any way to resolve? Thank you guys Appreciate any answer and feedback
Joined: 11/01/2018(UTC) Posts: 133 Location: Wisconsin Was thanked: 61 time(s) in 38 post(s)
Greetings, That is a noteworthy observation, I consider this to be a bug. For what it is worth, to get the program to behave correctly, you can: - evaluate upon assignment (See variable 'D' below)
- utilize evaluation upon assignment: eval() (See variable 'F' below)
- nest two functions: mat2sys(vectorize()) (See variable 'G' below)
May this be of Good Help; ⚜ Kenny Lemens, P.E. ᵂᴵ |
I really Appreciate your quick and effective response. Yes, it works.
