Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 339 Was thanked: 26 time(s) in 25 post(s)
See please the attach. I cannot solve the system of equation by all the alpha values from 0 too 360 deg. Is there the better solver for this task? Or the better way for the solution. Chebyshevs-Foot-Stepping-Machine.sm (180kb) downloaded 12 time(s).
Joined: 26/07/2022(UTC) Posts: 35 Location: UK Was thanked: 22 time(s) in 19 post(s)
Your expressions for (x4, y4) were unnecessarily complicated. See attached (Also with a better initial guess for x0). Chebyshevs-Foot-Stepping-Machine_b.sm (177kb) downloaded 5 time(s).
1 user thanked StvMath for this useful post.
Originally Posted by: StvMath Your expressions for (x4, y4) were unnecessarily complicated. See attached (Also with a better initial guess for x0). Chebyshevs-Foot-Stepping-Machine_b.sm (177kb) downloaded 5 time(s). I'm sorry, but this is not correct. The coordinates of point 4 should depend on the length L.04.
Originally Posted by: OchkovVF Originally Posted by: StvMath Your expressions for (x4, y4) were unnecessarily complicated. See attached (Also with a better initial guess for x0). Chebyshevs-Foot-Stepping-Machine_b.sm (177kb) downloaded 5 time(s). I'm sorry, but this is not correct. The coordinates of point 4 should depend on the length L.04. Because L.04 is the same length as L.03 it does, in fact, implicitly depend on L.04. Check the two files for a few angles and you will see that they give the same results (except that my file works for all angles). Basically, I've used the fact that (x4 + x3)/2 = x0 and (y4 + y3)/2 = y0. If L.04 and L.03 are different lengths a weighted average would be used, i.e. (L.03*x4 + L.04*x3)/(L.03 + L.04) = x0 and (L.03*y4 + L.04*y3)/(L.03 + L.04) = y0. Edited by user 12 March 2024 10:26:25(UTC)
See please
See please Oh!, I see! Just double-click on the plot, select Traces, then for each of Traces 2 through 6 select Symbol style, then Circle.
Originally Posted by: StvMath Originally Posted by: OchkovVF ?? I don't see anything wrong with the plot!
See please Oh!, I see! Just double-click on the plot, select Traces, then for each of Traces 2 through 6 select Symbol style, then Circle. it's one bug?
Я суслика не вижу, можно поконкретнее описать и показать что не так с компонентом X-Y Plot? |
Originally Posted by: uni Я суслика не вижу, можно поконкретнее описать и показать что не так с компонентом X-Y Plot? Спасибо, Вячеслав, что откликнулся. Суслик вот в чем. На этом графике в его аргументе записана система с перечислением кривых. Chebyshevs-Foot-Stepping-Machine-Trace.sm (178kb) downloaded 1 time(s).Все ОК. Затем для компактности документа я захотел использовать переменную Plot. Формат графика сбился. См. картинку наверху и Chebyshevs-Foot-Stepping-Machine-Trace-Plot.sm (179kb) downloaded 0 time(s).
Я попробовал и мне трудно было повторить условия возникновения такого поведения.
Настройки не должны слетать, если количество графиков между пересчётами документа не меняется. Если возникла ошибка во время построения одного из графиков, то настройки сохраняются. Если вы изменили количество отображаемых графиков (а оно определяется только во время пересчёта), то остальные графики "забываются".
Рекомендация: отключить автоматический пересчёт на время подобных манипуляций.
Я подумаю о добавлении опции - сохранять настройки между пересчётами не только для исключительных ситуаций. Возможно была причина, по которой я оставил такое поведение. |
Originally Posted by: uni Я попробовал и мне трудно было повторить условия возникновения такого поведения.
Я подумаю о добавлении опции - сохранять настройки между пересчётами не только для исключительных ситуаций. Возможно была причина, по которой я оставил такое поведение. Спасибо! Заодно подумайте и о: 1. После ввода выражения кривой видно весь график. А то приходится долго крутить мышкой. 2. Возможность фиксирования разброса графика так, чтобы его мышкой нельзя было менять.
Was thanked: 3 time(s) in 3 post(s)
Я написал статью о лямбда-механизе Чебышёва. Smath почему-то анимацию не воспроизводит. Могу ответить на вопросы по вычислениям и системе. Решение получено при помощи метода Драгилева. http://razdvizh.site/chebl
Originally Posted by: grelkin2 Я написал статью о лямбда-механизе Чебышёва. Smath почему-то анимацию не воспроизводит. Могу ответить на вопросы по вычислениям и системе. Решение получено при помощи метода Драгилева. http://razdvizh.site/chebl Спасибо за ценную информацию, но ссылка не работает
