SMath Studio Forum
Questions
Text without "" quotation marks ?
Joined: 12/03/2024(UTC) Posts: 10 Was thanked: 1 time(s) in 1 post(s)
Is it possible to display the text from a definition without the quotation marks and colored text? I can fix colored text by printing B&W , but quotation marks are annoying.
Joined: 11/01/2018(UTC) Posts: 134 Location: Wisconsin Was thanked: 62 time(s) in 39 post(s)
Greetings,
By its very nature, a string needs quotations to indicate that it is a string.
As for the Color, you can adjust your settings in the Program Files Folder on your C-drive to change the color of a string object, but the quick way would be to select your math statements, and change the color of the text to an off-black in the formatting toolbar (black = reset defaults, but an a shade off of black will change the color of the text as desired).
May this be of Good Help; ⚜ Kenny Lemens, P.E. ᵂᴵ |
May this be of Good Help; ⚜ Kenny Lemens, P.E. ᵂᴵ Thank you, but i was looking for a way to make the text from string blend with normal text . Quoatation marks are a bit annoying...
SMath Studio Forum
Questions
