Joined: 12/03/2024(UTC) Posts: 11 Was thanked: 1 time(s) in 1 post(s)
Is it possible to draw an image like below using smath input values? I have to draw this cartigrans ,within these cartograms, the volume of flows is represented at an equivalent scale (eg 100 veh. = 1 mm width) of strips with width proportional to the flow volume. Thank you!
Joined: 15/04/2012(UTC) Posts: 1,997 Was thanked: 1132 time(s) in 727 post(s)
There are multiple ways to create variable-controlled graphics. The most advanced ones are - X-Y Plot plugin (explicit, parametric and implicit plots, polygons, geometric shapes, see https://doi.org/10.25933/opus4-2948) - Maxima Draw (requires Maxima plugin, see https://doi.org/10.25933/opus4-2949) - Modeller region (allows for graphical interactive input but is not easy to understand. See the Beam-FEA-example in the Extension manager) Note that neither of these approaches works in the cloud version. |
