Offline Ber7
#1 Posted : 31 May 2014 22:23:48(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
A program to build equidistants curve.
Curve is given by the coordinates of points, parametrically or implicitly
File Attachment(s):
Eqv1.pdf (153kb) downloaded 153 time(s).
Eqv2.pdf (145kb) downloaded 83 time(s).
Eqv1.sm (26kb) downloaded 89 time(s).
Eqv2.sm (75kb) downloaded 78 time(s).
thanks 1 user thanked Ber7 for this useful post.
on 01/06/2014(UTC)
Offline Ber7
#2 Posted : 17 August 2014 12:33:39(UTC)
Ber7
Israel
Construction of parallel curves to a given curve
on the surface by the method A.B.Иванов
http://www.mapleprimes.c...-Algorithm#comment200379
Curve, which is given, is the line of intersection of a given surface and the auxiliary surface
File Attachment(s):
Paralle1Surfaces.pdf (703kb) downloaded 77 time(s).
Paralle11.smz (13kb) downloaded 66 time(s).
Paralle12.smz (11kb) downloaded 63 time(s).
on 17/08/2014(UTC)
Offline алексей_алексей
#3 Posted : 24 December 2014 21:37:11(UTC)
алексей_алексей
Was thanked: 13 time(s) in 8 post(s)
Variants of equidistant realized in Maple, including a spiral, rolling on a flat curves and curves on surfaces.
https://vk.com/doc242471809_317902338
https://vk.com/doc242471809_317902423
https://vk.com/doc242471809_318166068
https://vk.com/doc242471809_325420725
https://vk.com/doc242471809_318387654
https://vk.com/doc242471809_318413246
https://vk.com/doc242471809_318631384
https://vk.com/doc242471809_319585125
https://vk.com/doc242471809_323502291
https://vk.com/doc242471809_323475039
https://vk.com/doc242471809_326839986
https://vk.com/doc242471809_337748244
https://vk.com/doc242471809_343477990
https://vk.com/doc242471809_343244682
https://vk.com/doc242471809_343068740
https://vk.com/doc242471809_343068414
https://vk.com/doc242471809_343068048
https://vk.com/doc242471809_341981154
https://vk.com/doc242471809_340301415
https://vk.com/doc242471809_339747442
https://vk.com/doc242471809_339325456
https://vk.com/doc242471809_339196723
https://vk.com/doc242471809_339192605
https://vk.com/doc242471809_338645739
https://vk.com/doc242471809_339100828
https://vk.com/doc242471809_337778475
https://vk.com/doc242471809_334742039
https://vk.com/doc242471809_334527602
https://vk.com/doc242471809_333683192
https://vk.com/doc242471809_330688214
https://vk.com/doc242471809_335340765
https://vk.com/doc242471809_330956953
https://vk.com/doc242471809_334963570
If interested, the basic texts of the expansion .mw can be found at the following links:
http://www.mapleprimes.c...erested-In-The-Algorithm
http://www.mapleprimes.c...lling-Without-Slipping--
Offline grelkin2
#4 Posted : 24 October 2021 19:48:41(UTC)
grelkin2
Was thanked: 3 time(s) in 3 post(s)
To obtain equidistant use transformation to polar coordinate or solve quadratic equation
equid.avi (3,170kb) downloaded 17 time(s).
