Hello all, See please some amazing video presentations of using units in SMath made by Gilberto Urozz - Instructional videosYou can also reach these pages from Examples on the SMath Wiki. Many thanks Gilberto Regards, Radovan Edited by moderator 23 September 2010 15:40:27(UTC)
| Reason: Misspelling fixed in the title |
Just WOW! Many thanks to Gilberto Urozz for these great lessons! Radovan, thanks for the info! Regards. Updated: I've uploaded video files to the smath.info server in order to provide a mirrors for videos. Here is the list: Edited by user 23 September 2010 15:41:20(UTC)
Btw, I saw the videos and have found a small issue that causes a wrong Cursor position when working with Units (actually not only Units). Its a minor thing but it is happened too many times. It appears if one will input: 2*3' - after the apostrophe is filled in Cursor will be set to the 2*3 expression and not inside the empty placeholder. It is fixed now. Regards.
