There are operations and functions that can not be performed with units. There is no sense to use sin(x) or ln(x) where x is a variable with units - you can not have the result. These functions are not defined on values with units. General advice is to avoid using units with those functions.
Regards, Radovan |
I am having some problems using units with the solve command.
Hello. You should get rid of units before using solve function. See also: units and trunc()Best regards, Andrey Ivashov.
Hello asdfghjkl, Here is an example just to clarify the things (units are irrelevant - put your own instead): Regards, Radovan |
Could it be possible some function to affect every variable used within Solve ? i.e. a function to automatically get rid of all units when using solve. There might be a counterpart function to get back this units. I think this feature would be immensely useful.
