Offline olik
#1 Posted : 26 November 2015 22:57:20(UTC)
olik
Rank: Member
Czech Republic
Was thanked: 3 time(s) in 2 post(s)
augment x.sm (7kb) downloaded 30 time(s).
Hello.
It is not possible to plot an augment function with 'x' as parametr.
Is it a bug, or some special feature of 'x'?
regards Olik
#2 Posted : 27 November 2015 02:40:18(UTC)
This is not a bug. In the 2D plot region x and t are special unknowns (abscissa and animation parameter); both are parsed as local variables (doesn't matter if there are these variables on the canvas as defined values - except for t that can be used if you don't animate the plot). Therefore when you write augment(x,y) you are trying to augment each x displayed in the plot with y.
Obviously you can define the input matrix before the plot, outside the region placeholder; in this case x and y are parsed outside the plot and the input is simply the 3x2 matrix.
The X-Y plot works differently.
Edited by user 20 May 2016 22:25:36(UTC)  | Reason: marked as solved
on 27/11/2015(UTC)
Offline olik
#3 Posted : 27 November 2015 18:47:05(UTC)
olik
Rank: Member
Czech Republic
Thanks.
Are there SMath other special unknowns? Or functions with special unknowns?
I think - for example - 'x' in integration ( int(T(x),ΞΎ,0,x) ).
Regards Olik
p.s.
I posted a question about it:
http://en.smath.info/for...ion-can-I-integrate.aspx
#4 Posted : 27 November 2015 20:49:27(UTC)
In general, only lastError [this variable will be overwritten by any function giving an error.] and maybe i (there should be a post by Martin Kraska somewhere about issues noticed using i in some special case) and e.
