SMath Studio Forum
Bugs & Problems
[LINUX] "Attempted to divide by zero" when saving file
Hey all, I have a problem with SMath. Since I've updated my system to Ubuntu 15.10 I cannot save files in SMath. Everytime I try to "save" or "save as" I get the message "Attempted to divide by zero." See attached screenshot. Only except when the sheet is complete empty. I have installed the latest version of mono. Is something more missing? This is what the terminal gives on startup: WARNING: The runtime version supported by this application is unavailable. Using default runtime: v4.0.30319 - [AppDir] HTML Export (1.13.5737.24525) - [AppDir] Export to image (1.9.5737.24526) - [AppDir] Picture Region (1.10.5737.24525) - [AppDir] Plot Region (1.9.5737.24527) - [AppDir] SMath Studio Files Plugin (1.9.5737.24527) - [AppDir] Special Functions (1.11.5737.24524) - [AppDir] Text Region (1.10.5737.24526) - [AppDir] SMath Viewer Files Plugin (1.1.5737.24528) - [AppDir] XMCD Files Plugin (1.12.5737.24526) What does the warning mean? Best regards, Florian Edited by moderator 21 May 2016 02:28:22(UTC)
SMath Studio Forum
Bugs & Problems
