Offline aishen
#1 Posted : 17 March 2016 10:16:12(UTC)
aishen
Rank: Member
France
I left SM because on ubuntu it didn't work any more (cil winform no more on it)
I would like to see if its better working now with RC3 (the other have same problem)
I run the mono sm but doesen't start, then I run mono sm exe and it works... When loading a file everything is messed, when saving it crashes or says division by zero (for example sqrt(16) = 4 but saving doesn't work
Any help, I tried last ubuntu's 15.04 15.10 and 16.04 same problem.
Meanwhile I installed it on w10 virtualbox and works fine !
Thanks for this good soft hope we can get it back on linux Good
Henri
Edited by moderator 20 May 2016 22:02:54(UTC)  | Reason: added Linux tag
Offline overlord
#2 Posted : 17 March 2016 11:18:37(UTC)
Turkey
Was thanked: 509 time(s) in 339 post(s)
also not working on fully upgraded Arch Linux with Mono
Offline Andrey Ivashov
#3 Posted : 23 March 2016 00:58:17(UTC)
Rank: Administration
Cannot reproduce.
Just tested latest SMath Studio 0.98 (RC4) with latest Mono on fresh openSUSE. Everything works fine (complex worksheets, different plug-ins, etc.)
Offline ElSid
#4 Posted : 02 April 2016 04:34:07(UTC)
ElSid
United States
So I decided to jump onto the Linux foray this evening ... first time! Mint 17.3 XFCE on an old VISTA machine. I found instructions on how to install mono online.
Installed version 4.2.3.
I then downloaded the latest version (THANKS Andrey) and "unzipped (tar.gz?)" the the files into a public directory.
I then ran the desktop exe and it fired up! Doing good ...
Then I ran into a problem. I created a shortcut in the same folder where SMath is located and it opens ... BUT, when I move that shortcut to the desktop, nothing.
Again, first Linux experience, total newbie. Did I miss any Linux settings or is it a bug? I honestly think it's me, as the shortcut link works withing the SMath folder.
I'd take a picture, but don't know what "snipping tool" to use
