Offline mikekaganski
#1 Posted : 22 April 2016 12:40:34(UTC)
mikekaganski
I observe strange results from using constructs like vectorize(vectorize(M)), where M is a matrix which elements are matrices.
Could someone explain the logic? Or is this a bug?
nested-vectorize.sm (19kb) downloaded 19 time(s).
Edited by moderator 20 May 2016 21:18:42(UTC)  | Reason: marked as issue
Best regards,
Mike Kaganski
#2 Posted : 22 April 2016 22:41:09(UTC)
Mike,
Your M matrix is a collection of items. Mathematica defines as 'cell array'
Matlab defines MDA [Multi Dimensional Array]
The vectorie operator must have at least two arguments to produce.
You are attempting to vectorise M over itself, a non sense in some way.
Try to multiply M*N, where 'N' will be of similar construct of different
values and put that under the vectorise operator. You should get result.
