Offline Basile
#1 Posted : 05 June 2016 06:03:22(UTC)
Basile
In AC circuit analysis the VA (Volt Ampere) and VAR (Volt Ampere Reactive) are used.
It will be nice to be added.
All are equivalent to Power in dimensions.
Basile
#2 Posted : 05 June 2016 19:02:12(UTC)
It will be nice to be added [W=VAR]. All are equivalent to Power in dimensions.
Basile
Can you provide an example that creates problem not having "VAR" if VAR=W.
Offline Basile
#3 Posted : 05 June 2016 19:27:46(UTC)
Basile
Jean,
Currently, I defined the units and use them.
I propose that the VA and VAR become part of the power UNIT.
Basile
Offline Basile
#4 Posted : 05 June 2016 19:30:11(UTC)
Basile
Jean,
In AC circuit analysis, there are three "kind" of power.
Real, measured in W
Reactive, measured in VAR
and,
Apparent, measured in VA.
This is how it is done.
Basile
