Offline Basile
#1 Posted : 05 June 2016 06:07:03(UTC)
Basile
The xy2pol looks that still has problems with units:
Basile
Edited by moderator 07 June 2016 23:30:43(UTC)  | Reason: marked as bug
#2 Posted : 05 June 2016 19:34:47(UTC)
Offline Basile
#3 Posted : 05 June 2016 19:53:42(UTC)
Basile
Jean,
In your example:
The Magnitude (length) and The Angle (angle) in polar coordinates have different units. The rad is not a common unit. It is not correct.
In my example:
Look again please:
This was solved in recent upgrade by Andrey but apparently remains in the xy2pol.
http://en.smath.info/forum/yaf_postst7552_Units--Operation-cannot-be-performed.aspx
Basile
Edited by user 05 June 2016 19:56:54(UTC)  | Reason: Not specified
#4 Posted : 05 June 2016 21:14:46(UTC)
Better be in harmony wth the maths and Smath.
There is nothing to look gain, Smath is OK.
For sure they have different units: one is in "UnitGraph" the other is in "rad"
YES: rad is correct, rad is the maths unit in trig approximations as well as in official tables.
If you want °: convert by appending ° in the Smath result
Offline Basile
#5 Posted : 05 June 2016 23:22:05(UTC)
Basile
Jean,
1.
Please go previously and see the picture.
"rad" is the unit for both the magnitude and angle.
There is ONE placeholder for ONE unit.
YES: rad is correct, [YOU JUST SAID THAT ONE IS LENGTH THE OTHER ANGLE!!!] rad is the maths unit in trig approximations as well as in official tables.
2.
In this specific set of applications I have no interest in "numerical MathEMATICS". I use units. Thank you.
Basile
Offline mikekaganski
#6 Posted : 05 June 2016 23:38:16(UTC)
mikekaganski
@Basile,
Just show what you are trying to describe verbally Good
Not that it would convince anyone who doesn't wish, though.
Best regards,
Mike Kaganski
thanks 1 user thanked mikekaganski for this useful post.
on 07/06/2016(UTC)
Offline Basile
#7 Posted : 05 June 2016 23:52:10(UTC)
Basile
Mike,
The xy2pol does not work when units are included:
Do we agree?
When eventually it is working:
The units of the "Magnitude" and the units of the angle, (for the case of complex numbers here), will be different.
Note: I see you got W(att) how?
I see that you have a semicolon ( ; ) I have a comma (,).
Re(S);Im(S) versus Re(S),Im(S)
Basile
Offline Razonar
#8 Posted : 06 June 2016 01:26:10(UTC)
Razonar
Uruguay
Was thanked: 828 time(s) in 525 post(s)
Something like that?
Notice that atan2 ins't in SMath, which is more correct than atan for this functions (see http://www.mathworks.com...lp/matlab/ref/atan2.html for example).
on 06/06/2016(UTC)
#9 Posted : 06 June 2016 01:55:50(UTC)
mikekaganski
Originally Posted by: Basile Go to Quoted Post
Mike,
Do we agree?
Yes we do Good
Yes, that's what I show in my screenshot, that uses ≡ instead of =, just to show the desired result: seeing is better than reading.
Now I suppose it's apparent: Ctrl+= and manually make system with desired result Good
Russian locale default settings Good
Best regards,
Mike Kaganski
#10 Posted : 06 June 2016 01:57:34(UTC)
In this specific set of applications I have no interest in "numerical MathEMATICS". [Basile]
From A...Z, Smath is a numerical math tool as any other CAS and including your specific application.
xy2pol result is a vector of two components that need no unit as they are implicit. Extract each
component and append a dead unit decoration for clarity to yourself and the reader.
#11 Posted : 06 June 2016 02:03:39(UTC)
mikekaganski
atan2.sm (36kb) downloaded 14 time(s).
Best regards,
Mike Kaganski
Offline Razonar
#12 Posted : 06 June 2016 02:58:58(UTC)
Razonar
Uruguay
Hi Mike. I prefer this other, but have some round inconvenients:
atan2.gif atan2.sm (45kb) downloaded 9 time(s).
#13 Posted : 06 June 2016 03:04:35(UTC)
mikekaganski
I guess that with the new try function samebody can make a good one atan2.
But with try, it won't differentiate again.
Best regards,
Mike Kaganski
Offline Razonar
#14 Posted : 06 June 2016 03:10:02(UTC)
Razonar
Uruguay
Oh, I think that this happen only to me :-). Not very sure that try don't accept diff.
So, this with numerical optimization must to be the best solution (until atan2 not be in SMath):
Edited by user 06 June 2016 03:13:09(UTC)  | Reason: Not specified
#15 Posted : 06 June 2016 03:24:33(UTC)
mikekaganski
It's a good option, and only ~30% slower.
Best regards,
Mike Kaganski
#16 Posted : 06 June 2016 16:11:40(UTC)
Like this Alvaro: look for the Matlb code in the f(x) menu,
look for mwatan2 ... if you have in your version: then go
Maths atan2.sm (11kb) downloaded 11 time(s).
