SMath Studio Forum
Feature Requests
Show dot before leading multiplicator in Units placeholder
Using a leading multiplicator (like, say, 10^-3) in a Units placeholder makes the resulting display "wrong": there is no "multiplication" sign between the result number and multiplicator. Currently, there is a way to workaround this, using an invisible "separator" (nonbreaking space is treated like usual variable name), but this is not obvious and a kind of kludge. DotBeforeMultiplicator.sm (4kb) downloaded 32 time(s).Is it possible to show the dot if the first component in the units placeholder is a number, not a unit? |
Best regards, Mike Kaganski |
Quite right: the multiplication operator is implicit, thus not diplayed. 5346 was much more conventional ,,, 0.1mW=0.0001W
SMath Studio Forum
Feature Requests
