Implementation is in progress, but here is what we have for now: ss_debug_1.gif (646kb) downloaded 870 time(s).I believe it will make worksheets debugging much easier!
on 21/07/2016(UTC), on 21/07/2016(UTC), on 21/07/2016(UTC), on 21/07/2016(UTC), on 21/07/2016(UTC), on 21/07/2016(UTC), on 21/07/2016(UTC), on 31/08/2016(UTC)
Looks very promising! Thank you Andrey for all your work for SMath Studio! Kind regards csb
Joined: 01/08/2010(UTC) Posts: 115 Location: Rome Was thanked: 13 time(s) in 13 post(s)
Wonderful Andrey this is a really top rated feature for Smath Studio. Keep on the good work and the good ideas .
Franco
The debug delivered with Smath official release 5346 is not bad at all: divide by zero, arays don't match, undefined ...result is above One debug puzzled me for a while, explain: sometimes, when plotting user function, you will get an underscore followed by a number _ -X.XXXXXX .... it indicates non computable number
Latest SMath Studio beta released: http://en.smath.info/for...-5997--02-June-2016.aspxOne can play with debugging functionality there. Please note: - Buttons in main toolbar are rearranged;
- Super handy Pause button implemented - you can found a place where calculation in progress right now in one click! Previously it was absolutely impossible for large worksheets;
- Watch panel displays changed values in red - it makes much easier to understand what was changed since last step;
- Breakpoints can be set/removed before calculation started and also when calculation is already in progress;
- Vertical scrollbar improved to show locations of the regions with breakpoints.
I will slightly improve debugging functionality in future releases and will fix some bugs, but it looks for me very powerful even today! I also realized, that this feature can also be used in understanding the logic of SMath Studio and in learning to show students ordering of operations in loops and between assignments. One thing I do not understand is why Mathcad do not offers the same possibilities... or at least I did not found anything similar there. Best regards! Edited by user 22 July 2016 03:14:51(UTC)
on 22/07/2016(UTC), on 22/07/2016(UTC)
Originally Posted by: Andrey Ivashov One thing I do not understand is why Mathcad does not offers the same possibilities... or at least I did not finnd anything similar there.
On not too long program, Math 11 tracks error coding [highlight red] pretty well. However, the code may be correct but the maths may not be productive or wrong ! Many collabs dmanded for higher level of bug tracking. I have recollection Tom G. did produce some supplementary "check code", but I had no real need for it. I may still have that coding. Jean
Some improvements introduced into latest nightly build: - Step Into allows to go inside simple functions (i.e. even if they are not procedures); - Tooltip for items in debug window.
on 25/07/2016(UTC), on 02/10/2016(UTC)
