Helo Everyone! I have one question: imagine the matrix of size 15x15 filled with zeros. I want to put smaller matrix 5x5 to the bigger one but from column 2 to 6 and to rows 4 to 8. How can I do this? Edited by user 05 October 2016 17:13:56(UTC)
| Reason: drawing added
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
Oh, thank You a lot. It seems that this activity is much more complicated than in case of MathCad. But where can I take function "merge" from?
It is the first function in the worksheet linked above (you can download it and copy the function in your own worksheet)
How it works in Mathcad? |
I attached a pdf file (polish language ) which presents calculations of critical factor "alfa cr" for steel frame (see: Eurocode 1993-1-1). The most interesting formulas can be found on page 10 of this document. projekt16.pdf (321kb) downloaded 62 time(s).
... next: try NOT to isolate "M"
Originally Posted by: rafalSM but from column 2 to 6 and to rows 4 to 8 Please note that SMath's count of rows/columns starts from 1, not 0 (as your question implied). |
Best regards, Mike Kaganski |
Originally Posted by: mikekaganski Please note that SMath's count of rows/columns starts from 1, not 0 (as your question implied). Quite right: Davide "merge" is Smath style based on index ORIGIN = 1 Jean "replace" is Mathcad style based on default ORIGIN = 0
Converting your *.PDF [Mathcad] to Smath looks quite an entreprise. In the mean time, the "Matrix Treasury" may content useful modules. Jean Utilities Matrix Treasury Copy.sm (316kb) downloaded 53 time(s).
Originally Posted by: Davide Carpi It is the first function in the worksheet linked above (you can download it and copy the function in your own worksheet)
How it works in Mathcad? But you was able to create such a type of function. How did you do it?
Originally Posted by: rafalSM But you were able to create such a type of function. How did you do it? Something I don't understand: OK you are new to Smath and presumably you may not be familiar about it. The Mathcad PDF, did you do it yourself ? If so: you are already in Smath. Am immense amount of Mathcad stuff is convertible in Smath by many similarities in the programme code and algorthmic construction. I glanced through the PDF and noticed "eigvec & eigval". If you need, there is an Smath document doing. Cheers, Jean
