Hi all. I'm stuck about how can I insert reference formula into my home assignment. Because they may have extended syntax or simply they should appear twice in the document. First time as a reference formula, second as a calculation. And when they appear for the first time I don't won't SMath to translate them. The best way I found is to type formula in the on-line Latex converter and then insert them as picture. Edited by user 24 January 2017 09:08:37(UTC)
just use only logical equal to (CTRL+=) in your reference formula and nothing is going to be calculated.
Regards, Radovan |
