SMath Studio Forum
Questions
API - Entry.Create() with unit
Joined: 20/02/2017(UTC) Posts: 5 Was thanked: 1 time(s) in 1 post(s)
Hi, I am beginning my yourney into SMath API. My current bigest problem is how to add a unit to custom function return value. I am using IPluginLowLevelEvaluationFast interface and in my TryEvaluateExpression implementation I am returning some double value by: result = Entry.Create(TermsConverter.ToTerms(sampleDistance.ToString())); It works ok, but the question is: how to add unit to result of TryEvaluateExpression, for example standard length measuer - meters ? Can it be dony by Terms of result of function TermInfo? Any help will be apreciated
Hello Gregi,
Could you please post your smath-file or at least a screenshot, so i can understand your question better?
Regards, csb
One possible way. Code:var expr = new List<Term>();
var val = new Term( "10", TermType.Operand, 0 );
var unit = new Term( "'m", TermType.Operand, 0 );
expr.Add( val );
expr.Add( unit );
expr.Add( new Term( "*", TermType.Operator, 2 ) );
Thank you uni! Your solution is exactly what I needed
SMath Studio Forum
Questions
