I think you want to clear variables x and y before the definition of Phi. That seemed to get result to evaluate for me. It isn't exactly the same value as shown in the Mathcad Snapshot, but its close. Edit: The other thing you could do is change the variables of integration to something other than x and y. Edited by user 28 April 2017 01:03:57(UTC)
... thanks collab for helping. I don't catch "Clear(x,y)" Worst: it must be evaluated !!! Clear(x,y)=1 [Accepted]. One bug remains in 6179: if the function is complex, CAN NOT use index 'i' ... a minimal setup is now running. Will report is it stops calculate. Smath integrator is horribly slow, even at minimal accuracy.
... to be tried: instead of absolute in the "P for loops" the Matlab code may be more effective. To get the Greek letters in the forum: copy/paste from the Smath work sheet.
