Offline veb
#1 Posted : 13 July 2017 13:57:06(UTC)
veb
I'm a Russian engineer. We have a lot of calculations which, depending on the parameter chosen earlier, change the future types of data to be entered. For example, when calculating the ground: If the rod is a round data set one. And if you select a corner, then the data set is different. How to solve the problem of choosing formulas I found, but there is no input of data types.
I want to make a simple calculation with an output list of bar types, and below them is the data entry area, which will vary depending on the selected rod. Most likely this function already exists and is solved as an area, but I did not find an example. Help please an example or say there is such a functional?
The final calculation would be desirable to see in the form of a well-designed SMAth Viewer
Sorry for my english!
Offline veb
#2 Posted : 13 July 2017 14:42:17(UTC)
veb
Additional explanation. Replacing one parameter with another depending on the type selected "Круглый" or "Уголок"
#3 Posted : 13 July 2017 14:52:36(UTC)
Was thanked: 460 time(s) in 353 post(s)
My friend: your English drinks like best Vodka !
Can you attach some references [web, other sources ...]
If the rod is circular: the external contours get progressively
square along the diagonal [corners] ... is that what you are saying ?
It may just be a matter of 2D linear spline along the diagonal ?
In fact: Mathcad 11 contour plot would show such "squaring the circle",
from which an image can be captured, then converted in matrix values.
Welcome to Smath Community ... Jean
PS: Tom G. [former Mathsoft Collab] designed a program to extract the matrix contours.
A piece of gold, may not be possible/difficult to code in Smath.
Maybe your friend Andrey would be willing to give it a try ?
Offline veb
#4 Posted : 13 July 2017 15:34:15(UTC)
veb
I love Vodka!
A new simple example is the question:
There are two formulas: the sum and multiplication
When selecting a sum in the viewer, only the parameter b
When selecting a multt in the viewer, only see the parameter c
Now I see both parameters, although one of them is not needed
Is it possible to remove one of the options depending on the choice?
PS: When I drink vodka with my friend Andrew, we will discuss this topic
Offline ndv82
#5 Posted : 14 July 2017 10:58:59(UTC)
ndv82
Try this method: Answer1.sm (5kb) downloaded 16 time(s).
thanks 1 user thanked ndv82 for this useful post.
on 19/07/2017(UTC)
Offline veb
#6 Posted : 14 July 2017 11:19:30(UTC)
veb
Thank you so much! This works for me. I would like to be more elegant, but this method is also workable.
I'm in the thread discussing the project:
I think that such an opportunity could be useful, especially in Smath Viewer. Maybe someone will develop it in the form of an additional module.
I see this as an area that already exists. Depending on the selected matrix element, the elements inside the region disappear and others appear. It is necessary to expand the possibility of the existing field.
This is important and convenient when the calculation is done for the SMath Viewer
Edited by user 14 July 2017 11:25:38(UTC)  | Reason: Not specified
#7 Posted : 14 July 2017 16:55:52(UTC)
I'm done with squaring the rod ! Just suggestive.
You guys from Russia you can put "description" left/right/up.
I couldn't find the left/right ways of putting description ?
Image Gaussian Spot Diagonal.sm (44kb) downloaded 9 time(s).
#8 Posted : 14 July 2017 17:38:32(UTC)
Was thanked: 862 time(s) in 574 post(s)
When the region is focused, you can see that the left edge of the description is dotted; that is a "grip zone", click and drag around the region to change his position
Edited by user 14 July 2017 17:45:49(UTC)  | Reason: Not specified
Best regards,
Davide
If you like my plugins please consider making a donation to SMath Studio
#9 Posted : 14 July 2017 19:17:37(UTC)
Thanks Davide ! Smart Smath ... cheers: Jean
