2 Pages<12
#21 Posted : 09 August 2013 01:01:39(UTC)
Originally Posted by: ioan92 Go to Quoted Post
"The variables should be assigned to their desired values only after the function is defined." sic!
That's true only if you don't use line() to define your function; in this case to avoid the behavior you must set the optimization of the function definition to "numeric".
Edited by user 09 August 2013 01:07:13(UTC)  | Reason: Not specified
on 09/08/2013(UTC)
Offline kilele
#22 Posted : 09 August 2013 03:03:58(UTC)
kilele
All in all, SMath functions are called ALWAYS using call by reference also known as pass by reference.
That is, the function can modify the variable used as argument.
Look this post about global and local variables / scope of variables
This is a bit away from the original subject reporting a units bug. Good
Edited by user 09 August 2013 03:41:55(UTC)  | Reason: Not specified
thanks 1 user thanked kilele for this useful post.
on 09/08/2013(UTC)
#23 Posted : 23 March 2014 14:35:58(UTC)
You might vote for the bug report http://smath.info/bts/Is...s/IssueDetail.aspx?id=26 as the unit simplification issue is really nasty.
Edited by user 24 March 2014 19:29:04(UTC)  | Reason: Not specified
Offline kilele
#24 Posted : 24 March 2014 19:03:38(UTC)
kilele
You might vote for the bug report http://smath.info/bts/Is.../IssueDetail.aspx?id=26, as the unit simplification issue is really nasty.
the link does not work because of the trailing comma, anyway this can viewed as vote buying, paypal me hard and I'll vote your bugs Biggrin
#25 Posted : 24 March 2014 19:37:26(UTC)
So what? Keep in mind that this was a hint on that the topic has been shifted to the bug tracking system. Thanks for the hint with the comma.
Offline Andrey Ivashov
#26 Posted : 24 March 2014 23:55:02(UTC)
Rank: Administration
Thank you! This issue is pretty critical. Will handle it asap.
All bugs I will manage using http://smath.info/bts/, so Features/Bugs subforums is redundant now.
on 25/03/2014(UTC)
2 Pages<12
