5 Pages123>»
Offline uni
#1 Posted : 18 August 2013 21:08:18(UTC)
uni
Was thanked: 1400 time(s) in 817 post(s)
Matlab Runtime Library
SMath Studio compatibility SMath Viewer compatibility mono compatibility Platform Extension page Sources
CorFlags will help you to use this plugin on 64-bit system. mw prefix means: Matlab Workspace or MathWorks.
Functions list (blue color - implemented):
General Purpose Commands
Operators and Special Functions
Elementary Matrices and Matrix Manipulation
Elementary Math Functions
Data Analysis and Fourier Transform Functions
Polynomial and Interpolation Functions
Function Functions and ODE Solvers
Character String Functions
File I/O Functions
Data Types
Time and Dates
Examples:
matlab.ode.kinetic1.sm (9kb) downloaded 179 time(s).
matlab.ode.kinetic2.sm (14kb) downloaded 110 time(s).
matlab.ode.kinetic3.sm (13kb) downloaded 98 time(s).
matlab.ode.test1.sm (20kb) downloaded 98 time(s).
matlab.ode.test2.sm (19kb) downloaded 95 time(s).
matlab.ode.Amplitude detector.sm (21kb) downloaded 133 time(s).
matlab.ode.kinetic1.pdf (78kb) downloaded 135 time(s).
matlab.ode.kinetic2.pdf (92kb) downloaded 85 time(s).
matlab.ode.kinetic3.pdf (88kb) downloaded 77 time(s).
matlab.ode.test1.pdf (111kb) downloaded 95 time(s).
matlab.ode.test2.pdf (111kb) downloaded 78 time(s).
matlab.ode.Amplitude detector.pdf (149kb) downloaded 103 time(s).
Edited by user 09 January 2022 05:27:18(UTC)  | Reason: Not specified
File Attachment(s):
MATLAB C++ Math Library. Reference. Version 2.pdf (1,936kb) downloaded 629 time(s).
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
on 19/08/2013(UTC),  on 20/08/2013(UTC),  on 21/08/2013(UTC)
#2 Posted : 19 August 2013 01:41:11(UTC)
Was thanked: 1177 time(s) in 752 post(s)
Works for me. Does that imply that any matlab function could be used by SMath? Any chance for interactive plots? Ok, I know: Not so fast...
Pre-configured portable distribution of SMath Studio: https://smath.com/wiki/SMath%20with%20Plugins.ashx
on 19/08/2013(UTC)
Offline uni
#3 Posted : 19 August 2013 05:09:58(UTC)
uni
Chapter 25. MATLAB C/C++ Graphics Library 2.1 Release Notes
Using this library, in conjunction with the MATLAB Compiler and the MATLAB C/C++ Math Library, you can create stand-alone applications from M-files that use lines, text, meshes, and polygons as well as interactive visual interface components such as menus, push buttons, and dialog boxes.
Quote:
Note. You must use the MATLAB Compiler to create C or C++ stand-alone graphics applications. Calling MATLAB C/C++ Graphics Library routines directly from a C or C++ source module is not supported.
So, the answer is no.
I added a list of the available functions (MATLAB C++ Math Library. Reference. Version 2.pdf). Most of them, I think, can be used. The library has functions to solve the ODE: ode45, ode23, ode113, ode15s, ode23s.
on 19/08/2013(UTC),  on 19/08/2013(UTC)
Offline omorr
#4 Posted : 19 August 2013 18:47:38(UTC)
omorr
Rank: Administration
Serbia
Was thanked: 319 time(s) in 268 post(s)
It seems it works for me as well Good
By the way, I do not have Matlab installed, just followed the instructions and I could see and use the four mentioned function in SMath from the starting post (mw...). Not quite sure how this could be used without Matlab, but never mind - just wanted to try it on Good .
[EDIT] Did not understand what uni said about ODE: ode45, ode23, ode113, ode15s, ode23s Umnik ?
Edited by user 19 August 2013 18:49:54(UTC)  | Reason: Not specified
#5 Posted : 19 August 2013 18:52:31(UTC)
That sounds good. However, I don't know if any of these solvers has advantages over what we already have in various plugins.
How about the function find or fscanf?
Offline uni
#6 Posted : 20 August 2013 09:12:17(UTC)
uni
Updated. mwfind(1) added.
Radovan, this Math Library was created precisely in order to use the Matlab without Matlab.
There is one big problem when using functions from the library. The function can have a different number and different type parameters. Furthermore, a different number of the output data. SMath Studio doesn't support such features. I asked Andrew to think about it.
Edited by user 20 August 2013 09:24:50(UTC)  | Reason: Not specified
uni attached the following image(s):
on 20/08/2013(UTC),  on 20/08/2013(UTC),  on 20/08/2013(UTC)
#7 Posted : 20 August 2013 09:54:08(UTC)
Very nice. The real fun with find() comes if you can have matrix valued operands and results in boolean expressions. As these cannot be matrix-valued in
SMath, we at least need the matrix sign function. Uni, could you please add this?
In order to find all elements in M less then a number a, you would write in Matlab:
find(M<a), whereas in SMath that would look like mwfind(mwsign(a-M)+1)
Not really nice and comprehensible (the expression may well be wrong), but no loop required.
#8 Posted : 20 August 2013 10:41:16(UTC)
For the output parameters, an option would be to use embedded assignment, just like in Davide's findroot function. This is very transparant and handy. You would have an optional argument, being a vector of name=key pairs, where name is a variable name and key is an result item key. Your example then would look like
mwfind(mat(1,2,0,3,2,2),mat(I≡Index1,J≡Index2,V≡Values,3,1))
Of course, there are open questions: What should the return value be? Are there side effects of embedded assignments in nested expressions?
For providing optional input arguments, this would be an option as well. That would look a bit Python-like.
Offline omorr
#9 Posted : 20 August 2013 11:08:47(UTC)
omorr
Serbia
If I understood well all of this, these mw... functions will be introduced gradually into SMath, as soon as these and similar problems would be solved in SMath. Was I right about it?
Offline uni
#10 Posted : 20 August 2013 13:35:25(UTC)
uni
Updated. mwsign(1), mweq(2), mwge(2), mwgt(2), mwle(2), mwlt(2), mwneq(2) added.
Relational operations (Reference, p. 32).
Edited by user 20 August 2013 13:43:54(UTC)  | Reason: Not specified
Offline omorr
#11 Posted : 20 August 2013 14:30:29(UTC)
omorr
Serbia
Thank you uni. It seems I was right Acute
By the way, the second argument does not need to be a matrix. Scalar will do the job as well Good
Offline uni
#12 Posted : 21 August 2013 08:00:30(UTC)
uni
Updated. mwfprintf(4), mwfscanf(3), mwfscanf(4).
Yes, but it's an undocumented feature. The function takes a matrix as a parameter.
Edited by user 21 August 2013 08:15:52(UTC)  | Reason: Not specified
on 21/08/2013(UTC),  on 22/08/2013(UTC)
Offline uni
#13 Posted : 21 August 2013 13:53:30(UTC)
uni
Updated. mwode45(5), mwode23(5), mwode113(5), mwode15s(5), mwode23s(5) added.
mwode45(5) - (init, x1, x2, intvls, D) solve non-stiff differential equations, medium order method.
mwode23(5) - (init, x1, x2, intvls, D) solve non-stiff differential equations, low order method.
mwode113(5) - (init, x1, x2, intvls, D) solve non-stiff differential equations, variable order method.
mwode15s(5) - (init, x1, x2, intvls, D) solve stiff differential equations and DAEs, variable order method.
mwode23s(5) - (init, x1, x2, intvls, D) solve stiff differential equations, low order method.
File Attachment(s):
Matlab C++ Math Library. ODE solvers.sm (11kb) downloaded 150 time(s).
#14 Posted : 21 August 2013 23:52:44(UTC)
Now it is documented, but perhaps not officially supported ;-) Is there any chance to overload the operators? Do they have internal functions that could be overwritten?
Also, thanks for the file ops. Writing of strings is not supported so far?
I fail to read the datafile even if I remove the first line with the column titles. Would be interesting to see what performance we get.
One remark to function naming: This is of course entirely in the souvereignity of the plugin creator. Still I would make some recommendations, driven by
the objective, to make an SMath document as much math-on-paper like as opposed to program code.
- I'd recommend to shift the information on the function's origin from name prefixes like dn_, al_, mw... towards the dynamic assistant help string, much like it is done for the efi-loaded libraries.
- If a function is first or best in providing some feature (which quite frequently happens in your plugins), then please give it an intuitive generic name, perhaps with capital first character in order to indicate it as plugin-based. Example: dn_LinAlgEigenvalues() could well be Eigenvalues().
- technical information on which function actually is doing the job, might be shifted to the description string.
Surely, this all is a matter of taste and perhaps it is quickest, not to waste time on naming strategies. Either way, I try to keep up with documenting.
File Attachment(s):
Section matrix elementwise.sm (50kb) downloaded 94 time(s).
Section matrix operations.sm (80kb) downloaded 82 time(s).
on 22/08/2013(UTC)
Offline uni
#15 Posted : 22 August 2013 06:44:50(UTC)
uni
Updated. Now the installer is located within the plugin.
I'll remove all of the prefixes, when Andrey will support the functions with the different types of parameters.
In MATLAB all the parameters are of type matrix. Inside the plugin takes place an implicit conversion to a type of matrix if you use a scalar. Therefore, for example, for the function mwabs() the result is a vector (matrix). Special support for scalar parameters makes sense to do only when overloading will be realized.
on 22/08/2013(UTC)
#16 Posted : 22 August 2013 20:29:59(UTC)
Thank you for considering to rename functions. I also would not mind 1x1 matrix results to be converted to scalars by default, even if that might be mathematically a bit sloppy. But perhaps someone can give an example where that would be harmful...
#17 Posted : 22 August 2013 20:46:39(UTC)
I would like to point the user to the environment variable editor using the command line
"C:\Windows\system32\rundll32" sysdm.cpl,EditEnvironmentVariables
in the plugin handbook page.
but I have no idea how that can be made a link target in the hyperlink region (due to the " signs in the link). Davide, any idea?
An alternative would be that the installer tests for the presence of dll and path entry and adds the entry if required.
#18 Posted : 23 August 2013 00:03:14(UTC)
Was thanked: 1401 time(s) in 911 post(s)
This require to use an overload of the function that I've used inside the hyperlink region; I need to think how to unlock the feature without compromising those already existing....
P.S. I'm not sure that this command works after windows XP
on 23/08/2013(UTC)
#19 Posted : 23 August 2013 00:31:34(UTC)
I am using Win7 and got the command line from the program manager after clicking through the system control hierarchy. Faster is to locate the dialog via search for "Umg", german for "env".
#20 Posted : 23 August 2013 10:42:17(UTC)
There is an user interaction issue. After updating the plugin and re-starting smath,
the installer dialog pops up and offers installation. You are also informed that you do not need installation if you already have the runtime environment installed. In this case it is natural that the user chooses [Cancel]. Then, however, the dialog pops up every time you launch smath.
If you choose [Install] even if you know that nothing needs to be installed, then suddenly the installer gets aware of that and just finishes and no more messages appear on start-up.
on 23/08/2013(UTC)
5 Pages123>»
