2 Pages12>
Offline uni
#1 Posted : 28 August 2013 00:53:11(UTC)
uni
GNU Scientific Library (GSL)
SMath Studio compatibility SMath Viewer compatibility mono compatibility Platform Extension page Sources Examples
Functions list:
Solvers for Non-Stiff Systems:
gslrk2(init, x1, x2, intvls, D) Explicit embedded Runge-Kutta (2, 3) method.
gslrk4(init, x1, x2, intvls, D) Explicit 4th order (classical) Runge-Kutta. Error estimation is carried out by the step doubling method.
gslrkf45(init, x1, x2, intvls, D) Explicit embedded Runge-Kutta-Fehlberg (4, 5) method.
gslrkck(init, x1, x2, intvls, D) Explicit embedded Runge-Kutta Cash-Karp (4, 5) method.
gslrk8pd(init, x1, x2, intvls, D) Explicit embedded Runge-Kutta Prince-Dormand (8, 9) method.
Arguments:
- init is either a vector of n real initial values, where n is the number of unknowns (or a single scalar initial value, in the case of a single ODE).
- x1 and x2 are real, scalar endpoints of the interval over which the solution to the ODE(s) is evaluated. Initial values in init are the values of the ODE function(s) evaluated at x1.
- intvls is the integer number of discretization intervals used to interpolate the solution function. The number of solution points is the number of intervals + 1.
- D is a vector function of the form D(x,y) specifying the right-hand side of the system
Options:
- AbsTol - absolute tolerance parameter, default value 1E-7.
- RelTol - relative tolerance parameter, default value 1E-4.
Examples:
gsl.ode.integrate.sm (12kb) downloaded 87 time(s).
gsl.ode.kinetic1.sm (9kb) downloaded 82 time(s).
gsl.ode.kinetic2.sm (15kb) downloaded 72 time(s).
gsl.ode.kinetic3.sm (15kb) downloaded 69 time(s).
gsl.ode.test1.sm (20kb) downloaded 73 time(s).
gsl.ode.test2.sm (19kb) downloaded 71 time(s).
gsl.ode.Amplitude detector.sm (21kb) downloaded 96 time(s).
gsl.ode.integrate.pdf (93kb) downloaded 78 time(s).
gsl.ode.kinetic1.pdf (78kb) downloaded 72 time(s).
gsl.ode.kinetic2.pdf (93kb) downloaded 59 time(s).
gsl.ode.kinetic3.pdf (92kb) downloaded 53 time(s).
gsl.ode.test1.pdf (111kb) downloaded 61 time(s).
gsl.ode.test2.pdf (111kb) downloaded 61 time(s).
gsl.ode.Amplitude detector.pdf (149kb) downloaded 75 time(s).
Links:
1. GNU Scientific Library – Reference Manual.
2. GSL for Windows.
3. The GSL Team.
4. Thanks.
See also:
Mathcad Toolbox
DotNumerics
SADEL
Matlab C++ Math Library
OSLO
lsoda
Edited by user 13 January 2022 10:35:18(UTC)  | Reason: Not specified
File Attachment(s):
Russia ☭ forever
Viacheslav N. Mezentsev
thanks 4 users thanked uni for this useful post.
on 28/08/2013(UTC),  on 28/08/2013(UTC),  on 28/08/2013(UTC),  on 28/08/2013(UTC)
#2 Posted : 28 August 2013 01:21:50(UTC)
very very cool library, there are several interesting things Biggrinirol:
works for me (win 7 x64)
best regards,
Davide
Edited by user 28 August 2013 01:25:15(UTC)  | Reason: Not specified
Offline omorr
#3 Posted : 28 August 2013 08:18:41(UTC)
omorr
Rank: Administration
Serbia
I agree with Davide. I mentioned this library few times as well Good
As I said before, uni is like a man working in a candy store and giving us very good and healthy sweets for free Good Thank you
thanks 2 users thanked omorr for this useful post.
#4 Posted : 28 August 2013 10:27:27(UTC)
Uni,
I see you do not use prefixes any more. Does that mean, you are considering the GSL as the primary source of generic SMath functions? IMHO that would be sensible, as GSL seems to be the most vital and most free library among the ones you wrapped so far. However, I have no idea about performance issues.
on 28/08/2013(UTC)
Offline uni
#5 Posted : 28 August 2013 10:33:37(UTC)
uni
Functions that are not yet implemented not have a prefix. When I add a function in the plug-in, I add a prefix to it. All the functions in this library will have the same or similar names which given in their description.
For example: gsl_sf_bessel_J0() -> gslsfJ0(), gsl_sf_airy_Ai() -> gslsfAi(), ...
I'll ask Andrey to implement the namespace for functions. This option may be enabled and disabled as the description of the region. In this case, you can specify the function names without the prefix.
Edited by user 28 August 2013 10:47:39(UTC)  | Reason: Not specified
Russia ☭ forever
on 28/08/2013(UTC)
#6 Posted : 28 August 2013 11:50:52(UTC)
I am not sure that I understand correctly, what the namespace for functions concept is meant to be.
Is that something like local aliasing?
Is that a by-region setting?
What is the visualization concept?
I'd expect something like switching on aliasing (and perhaps enabling of the plugin) by a separate statement "with("GLS" ) or with("Matlab" ). This could be
deactivated later in the same sheet by a function without() in a traceable manner.
BTW, how about including a plugin hint in the description string of the functions. I had to search the forum in order to find out what plugin provides the erf() function (Davide, sorry for my leaking memory). Not a big deal for me, but would help to correctly direct user feedback.
Offline uni
#7 Posted : 28 August 2013 12:13:24(UTC)
uni
I think it only works for the document in text form. It is unlikely that this method will be useful in our case.
We have one example of namespace support. Not necessarily indicate the selected space, but the user should be able to select it. We can assign a hot key to display the namespace for the selected function.
uni attached the following image(s):
Russia ☭ forever
on 28/08/2013(UTC)
Offline kilele
#8 Posted : 28 August 2013 12:51:42(UTC)
kilele
I see viacheslav and davide more like fabulous dwarves blacksmiths and radovan and martin like mere mortal betatesters, thanks btw Biggrin
Edited by user 28 August 2013 12:53:26(UTC)  | Reason: Not specified
#9 Posted : 28 August 2013 15:04:36(UTC)
Ok, it is a Mathcad concept (I was not aware of that).
The example with m as units and m as variable does not really convince me. By math standards, these items should be distinguished by type face (italic for variables, upright for units or other items that are not supposed to change. SMath has this the other way around, but at least clearly indicates the difference. Thus, the unit name space tag is the apostrophe ' in front of the name.
There is another "namespace" then in SMath, the absolute variables with ~ as tag (which would be fine to represent matrix/vector values).
An option for getting along without new features would be to leave the prefixes in the names and to provide generic names pointing to the most appropriate function from whatever plugin it may come or even to provide wrapper functions like Findroot() to choose from what is available.
The ordinary ("mortal" ) user hardly wants to choose from 20 ode solvers or from 10 nonlinear solvers.
Offline uni
#10 Posted : 28 August 2013 18:21:27(UTC)
uni
Updated to GSL 1.16.
Russia ☭ forever
on 28/08/2013(UTC),  on 28/08/2013(UTC),  on 29/08/2013(UTC)
Offline uni
#11 Posted : 16 September 2016 16:37:36(UTC)
uni
Updated for the fully automatic build using Release Manager.
Russia ☭ forever
Offline overlord
#12 Posted : 23 June 2018 23:49:08(UTC)
Turkey
Was thanked: 509 time(s) in 339 post(s)
Installing this plugin causing forced close on Arch Linux + Mono.
After forced close you cannot be able to open Smath again unless manually deleting the plugin.
Offline uni
#13 Posted : 24 June 2018 00:36:27(UTC)
uni
Because the plugin is not compatible with Linux + Mono:
Quote:
VS2013, .Net 2.0, C#, C++/CLI, Win32 + x64
Win32 + x64 - means Windows only, C++/CLI - unmanaged code used.
Edited by user 01 August 2018 05:57:37(UTC)  | Reason: Not specified
Russia ☭ forever
Offline uni
#14 Posted : 01 August 2018 18:19:18(UTC)
uni
gslrkck simple test.
gslrkck.test1.sm (12kb) downloaded 41 time(s).
gslrkck.test1.pdf (49kb) downloaded 49 time(s).
Russia ☭ forever
on 02/08/2018(UTC)
Offline uni
#15 Posted : 12 December 2018 14:12:57(UTC)
uni
Updated.
Changes:
- zero point issue fixed;
- added support for the simple D(t,x) definition.
Russia ☭ forever
on 12/12/2018(UTC),  on 12/12/2018(UTC),  on 12/12/2018(UTC),  on 12/12/2018(UTC)
Offline uni
#16 Posted : 24 December 2018 18:50:43(UTC)
uni
Updated.
Edited by user 25 December 2018 02:48:35(UTC)  | Reason: Not specified
Russia ☭ forever
on 24/12/2018(UTC),  on 24/12/2018(UTC),  on 24/12/2018(UTC),  on 25/12/2018(UTC)
Offline uni
#17 Posted : 22 January 2019 03:23:03(UTC)
uni
Updated.
Added: gslmsadams(5), gslrk1imp(5), gslrk2imp(5), gslrk4imp(5), gslbsimp(5), gslmsbdf(5).
Fixed: gslrk1imp(6), gslrk2imp(6), gslrk4imp(6), gslbsimp(6), gslmsbdf(6).
Removed: gslmsadams(6).
Solvers with 5 arguments working with numerical Jacobian (not so good but I don't know how to improve it now).
Click to enlarge Click to enlarge
Edited by user 06 June 2022 13:07:22(UTC)  | Reason: Not specified
Russia ☭ forever
on 22/01/2019(UTC),  on 22/01/2019(UTC),  on 22/01/2019(UTC)
Offline uni
#18 Posted : 14 May 2019 16:33:45(UTC)
uni
I was on a journey.
This use of the library is beyond the scope of the forum. I will try to create a simple example, but you still need to read the original documentation to use the library.
Russia ☭ forever
Offline uni
#19 Posted : 21 May 2021 07:55:24(UTC)
uni
Updated.
Changes:
- updated to GSL 2.4.
Russia ☭ forever
on 21/05/2021(UTC)
Offline uni
#20 Posted : 09 December 2021 19:03:00(UTC)
uni
Plugin updated.
Changes:
- added support for ODE systems in mathematical form;
- refactored.
Russia ☭ forever
on 09/12/2021(UTC)
Guest (3)
2 Pages12>
