Was thanked: 8 time(s) in 4 post(s)
Hello all, I've been battling for a couple of days with this calculation sheet. I've got three problems: 1) in the Util block, the function freq_list returns an error message (red box and Quote:n ct not defined ), even if I can still get the results that I want. (I can't get rid of the smiley, but it's "no _ oct" without the spaces) 2) in the Propagation Constant section I still get the red box, but if I check the results, they are there. 3) in the Impedance section, despite it being a copy and paste of the Propagation Constant section, I get a "Syntax Error" message. Any suggestions? Edited by user 07 October 2013 11:11:36(UTC)
Done About the first issue: - line() uses the last placeholder to output the result on the "layer above" (the canvas in this case); so don't use a single line but a two line line() and place in the last placeholder anything that is already defined (the last placeholder works like an eval, in some way) About other issues there's a bug that involves the linear indexing and the assignments (I don't remember if was already reported here), so use the two-indices syntax to replace the Switch elements regards, Davide Edited by user 07 October 2013 16:02:58(UTC)
Can't get the thanks button to work on the forum, but: thanks very much!
P.S. I'm writing in English for the benefit of all Forum users, but I'm also Italian, albeit living abroad.
You're welcome P.S. I think that Andrey can solve the thank issue, if you contact him via pm |
