Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
Hi all, Here there is a plugin to have currencies and exchange rates in SMath Studio. Infos: Functions: - SetCurrencyUnits(1), SetCurrencyUnits(2): extends SMath Studio with currency units. When an internet connection is available, exchange rates are kept updated using the ECB reference rates (internet connection not required but useful);
Quote:The reference rates are usually updated by 3 p.m. C.E.T. They are based on a regular daily concertation procedure between central banks across Europe and worldwide, which normally takes place at 2.15 p.m. CET.
GetYahooExchangeRate(2): get a wide set of exchange rates from Yahoo Finance (internet connection required); service discontinued by Yahoo
>>> PLEASE REPORT IN THIS TOPIC ANY ISSUE, MORE DETAILED AS POSSIBLE <<< Edited by user 24 October 2018 02:07:23(UTC)
| Reason: description updated File Attachment(s): Davide Carpi attached the following image(s): |
3 users thanked Davide Carpi for this useful post.
on 17/12/2013(UTC), on 18/12/2013(UTC), on 18/12/2013(UTC)
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1125 time(s) in 722 post(s)
Nice work, Davide. However, does not work with , as decimal separator. |
Originally Posted by: mkraska Nice work, Davide. However, does not work with , as decimal separator. Thank you Martin, try with the update |
Better now, but still no connectivity. I guess that is sort of firewall or proxy issue. |
Unfortunately Davide, this does not work for me (Win7 x64). Plugin refuses to install properly. Regards, Radovan omorr attached the following image(s): |
ok... as for now the password is: TESTOriginally Posted by: mkraska Better now, but still no connectivity. I guess that is sort of firewall or proxy issue. Try again, I've made some changes... If doesn't work try NetTest(0) and NetTest(1) and post a screenshot Originally Posted by: omorr Unfortunately Davide, this does not work for me (Win7 x64). Plugin refuses to install properly. very strange... try again with this update; if doens't work got to %APPDATA%\SMath\Debug\CurrencyUnits and post the log file |
The results were overly wide, thus i cut them. mkraska attached the following image(s): |
Failed again Here is the log file Regards, Radovan File Attachment(s): log.txt (2kb) downloaded 52 time(s). |
Originally Posted by: mkraska The results were overly wide, thus i cut them. seems a proxy/firewall authorization problem... I suppose that NetTest("http://www.google.com" and NetTest("http://www.google.de" will produce the same results Originally Posted by: omorr Failed again
Regards, Radovan I've made another little modification, could you try again? |
It seems that this plugin is not going to install into the Martins' unofficial build. I figured out by the second line of the log file. I tried it on the official one and it seems to be Ok Regards, Radovan File Attachment(s): log.txt (12kb) downloaded 46 time(s). omorr attached the following image(s): |
Originally Posted by: omorr It seems that this plugin is not going to install into the Martins' unofficial build. I figured out by the second line of the log file. I tried it on the official one and it seems to be Ok
Regards, Radovan thank you Radovan, now I understand the plugin looks for the files in the %APPDATA% folder, I'll try to fix it [EDIT] UPDATED: this version should work properly both in the official and the unofficial versions Edited by user 17 December 2013 21:41:45(UTC)
Yes it works, thank you |
Originally Posted by: mkraska Better now, but still no connectivity. I guess that is sort of firewall or proxy issue. In our school LAN, the connectivity is broken, at home web access works (official and unofficial version). I shall include the plugin in the next release of the inofficial distribution. |
UPDATED- error handling: LOGs will be placed in the relative "extensions\debug\CurrencyUnits" folder (so the portable version has a portable debug path) - For developers only: added a log tool to output a Term[] tree representation (see the CurrencyUnits Implementer.cs). Davide Carpi attached the following image(s): |
UPDATED
- checks for network availability before each ECB update attempt; - LOG tools updated (session start is no longer registered) - NetTest() removed. |
The yahoo download service for exchange rates has been discontinued. See their forum post. Therefore, the function GetYahooExchangeRate() reports that the remote name could not be resolved. I recommend to adjust the error message to "Service discontinued by Yahoo. Use function .... instead." Perhaps some other source is available in replacement. However, I would not push this, because I rarely use it. Just cleaning up documentation. Edit: filed as SS-3559Edited by user 05 September 2018 13:33:24(UTC)
PLUGIN UPDATED SMath Studio 0.99.6839 and later- [SS-3560] restored unit as input argument in SetCurrencyUnits();
- [SS-3559] since Yahoo service is discontinued now GetYahooExchangeRate() is hidden in the dynamic assistance and returns directly an error message if called;
PLUGIN UPDATED SMath Studio 0.99.7739 Nightly Build and later- added Currency units (symbols) toolbox;
NOTE: - symbols are sorted by unicode code;
- symbols are subject to font implementation;
- these are decorative symbols; you have to define yourself exchange rates on the worksheet to mix them;
Edited by user 27 March 2021 18:50:47(UTC)
