![Daniel Daniel](/forum/images/noavatar.gif) Rank: Newbie
Joined: 02/10/2009(UTC) Posts: 2 Location: New Zealand
Hi Guys, This is some great software you have here and I commend you for the great effort that has gone into it! I have a question about how to address the answers from the following example: ![](http://www.iforce.co.nz/i/z5wa0dud.jpg) I tried addressing it as a vector, but it is a scaler so this will not work. Thanks in advance, Daniel
![omorr omorr](/forum/resource.ashx?u=274) ![](/forum/Images/Ranks/Administration.png) Rank: Administration Groups: Registered, Advanced Member Joined: 23/06/2009(UTC) Posts: 1,740 ![Man Man](/forum/Themes/yafvision/male.gif) ![Serbia Serbia](/forum/Content/images/flags/SP.png) Was thanked: 318 time(s) in 268 post(s)
Hello Daniel Daniel wrote:I have a question about how to address the answers from the following example: ![](http://www.iforce.co.nz/i/z5wa0dud.jpg) I tried addressing it as a vector, but it is a scaler so this will not work The Equation systems template should, actually, give a vector. Try this: x←10±5x=sys(15;5;2;1)el(x;1;1)=15el(x;2;1)=5As this is a vector you can omit the second index BTW, it seems there are some problems with Equation system. Please look at the http://en.smath.info/forum/default.aspx?g=posts&t=222Regards, Radovan Edited by user 02 October 2009 13:17:47(UTC)
Ahh I see, I was trying to access this using the matrix minor function thinking it was the same as what the key "[" provides (which I only just figured out too!). I could not find a reference to access matrix elements in your SMath tutorial, but did find it here: http://en.smath.info/for...t.aspx?g=posts&t=138
![Andrey Ivashov Andrey Ivashov](/forum/resource.ashx?u=4) ![](/forum/Images/Ranks/Administration.png) Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,616 ![Man Man](/forum/Themes/yafvision/male.gif) ![Russian Federation Russian Federation](/forum/Content/images/flags/RU.png) Was thanked: 1978 time(s) in 666 post(s)
Everything is true. Thank you Radovan
You are welcome, and welcome back |
![ElSid ElSid](/forum/images/noavatar.gif) ![](/forum/Images/Ranks/Advanced-Member.png) Rank: Advanced Member Groups: Registered
Joined: 05/03/2009(UTC) Posts: 433 ![Man Man](/forum/Themes/yafvision/male.gif) ![United States United States](/forum/Content/images/flags/US.png) Location: USA Was thanked: 17 time(s) in 15 post(s)
Nice to see vectors with single subscripts. Was a literal subscript (in Mathcad its the {.}) implemented? Also, do all matrix/array/vectors start at 1? In Mathcad the Origin defaults to "0". Either way is fine.
Hello ElSid ElSid wrote:Nice to see vectors with single subscripts. Was a literal subscript (in Mathcad its the {.}) implemented? Also, do all matrix/array/vectors start at 1? In Mathcad the Origin defaults to "0". Either way is fine. As I remember, few posts mentioned literal subscript. You are right, we (Mathcad users) are used to literal index notation. I think this is not implemented. The final decission is on SMath creators. Also, we are used to ORIGIN in Mathcad. As I remember, ORIGIN made problems in earlier version of Mathcad. I agree with you, starting index at 0 or 1 makes no difference, as far as I am concerned. In my experience, the only use of ORIGIN was to set it up to 0 or 1. I do not remember that I set it up to some other values. Regards, Radovan Edited by user 06 October 2009 02:24:16(UTC)
omorr wrote:Hello ElSid Also, we are used to ORIGIN in Mathcad. As I remember, ORIGIN made problems in earlier version of Mathcad. I agree with you, starting index at 0 or 1 makes no difference, as far as I am concerned. In my experience, the only use of ORIGIN was to set it up to 0 or 1. I do not remember that I set it up to some other values.
Regards, Radovan
Just curious to know which way the developer goes. Mathcad defaults to ORIGIN=0. For most people, ORIGIN=1 is initially easier, although thinking of an initial state (velocity sub initial) is typically written with 0 ![Good](/forum/Images/Emoticons/sm_smile_good.gif)
